Page 5 of 5 FirstFirst ... 3 4 5
Results 41 to 50 of 50
  1. #41
    Super Member
    Sengna's Computer Details
    Window 7
    8 GB
    AutoCAD 2016
    Jun 2012
    USA
    525
    Are the numbers in a logical sequence?
    Yes, they are
  2. #42
    Super Member
    Window 7
    8 GB
    AutoCAD 2016
    Jun 2012
    USA
    525
    Quote Originally Posted by Chilidawg View Post
    Then why are you embedding or linking the excel data?
    Select the cell in excel, then copy, switch to autocad, start a leader then when it comes time to enter the text, simply paste the data from the cell into the leader (it won't be an OLE object, just the raw text).
    Another option is to paste special as an autocad entity it will paste in as a table cell.
    If the OLE objects are linked, and not embedded, you can break the links, that might help with your crashing issue.
    Thanks, Chilidawg.........you are right I tried your first option, i double click on text leader and then i copied cell from excel and back to cad and paste inside the text leader, i have to do twice for each EQ but it's better for the long run.
    * for the 2nd option caused my cad file crash again today for paste as CAD entity as show below message. From now i won't use Paste special anymore.
  3. #43
    Senior Member
    AutoCAD 2017
    Jun 2013
    137
    Quote Originally Posted by Sengna View Post
    Yes, they are
    You might want to consider using the incrementing numer text LISP.
    Can someone provide a link to it?
    Thanks.
    edit
    on the other hand, if you are willing to rebuild all your leaders, I would stick to that method. that way the text will be linked to the leader.
    If you do ever have to change a number, you can always go to edit: Find: Replace text.
  4. #44
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,740
    The Incremental Numbering Suite is available at Lee Mac's website.
    http://lee-mac.com/numinc.html
    You're dealing with a 22MB drawing. Are your computer specs up to the task? How much RAM is installed?
  5. #45
    Super Member
    Window 7
    8 GB
    AutoCAD 2016
    Jun 2012
    USA
    525
    I will check that website, thanks
    My computer:
    Window 7, Intel Core I3 Processor, 8GB Ram
  6. #46
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,740
    Those specs aren't that great but you should be able to work with a 22MB drawing.
    What do you have for a graphics card?
    What version of Windows 7 is it (Home Edition, Pro, Ultimate, other)?
    Are you experiencing any other problems with your computer?
    Do you let Windows automatically download and install updates?
    Are you running an anti-virus program?
    What other programs are running in the background when you are working in AutoCAD?
    Have you purged and audited the drawing?
  7. #47
    Senior Member
    AutoCAD 2017
    Jun 2013
    137
    You might also want to consider breaking your files down a bit.
    In other words, make a copy of the file and delete all the layouts from that copy. Rename that file "Master drawing" (or whatever)
    How big is the file then?
    make four more copies of you original drawing and rename them "layout set 1" through 4.
    In each of those files, delete the drawing in the model space and drop in an xref of your file: "master drawing."
    This way you only have to change one file, the master drawing, to update the layout sets.
    then for each of the layout set files, purge out the 3/4 of the layouts. so that for the file "layout set 1" you have layouts 1 to 12, in "Layout set 2" you have layouts 13 to 24, etc.
    how big are the files then?
    create a new sheet set and import your layout files using the sheet set manager. make use of subfolders to organize your layouts.
    If you only open one layout set file at a time, you should be able to avoid crashing the system with out reworking all the excel links in your layouts.
  8. #48
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,740
    ^^^Good suggestion.
    Sengna: Are you working off of a network or on a standalone workstation?
  9. #49
    Super Member
    Window 7
    8 GB
    AutoCAD 2016
    Jun 2012
    USA
    525
    - I use Window 7 enterprise, i have to check the graphic card at work I can’t remember at this moment.
    -I notice that I can’t open another big file while I am working with this site EQ drawing, but if I am not working with this dwg, I could open like 4 or more CAD drawings at the same time. Other drawings are hardly ever crash only this one. I don’t have any problem with my computer .
    -- This is the standalone computer
    -- Windows automatically download and install updates at all time, there might be some anti virus running
    -I always do PURGE command for this drawing but I don’t have the express tool to use the OVERKILL command yet. Still on request with IT
  10. #50
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,740
    Maybe the reason you cannot open another big file while working on this 22MB drawing is that you don't have enough RAM and/or your virtual memory settings are too low.
    You do remember that we told you there is a difference between purge (no dash) and -purge (with the dash) right?
  1. "save" in the file "pull down menu" not working
    By kfarrar in forum Civil 3D & LDD
    Last Post: 25th Dec 2013, 10:22 am
  2. AutoCAD "fas" file autoloading in startup
    By Rajparamasivam in forum AutoLISP, Visual LISP & DCL
    Last Post: 9th Feb 2013, 05:49 pm
  3. saving as "step" and/or "inventor" file
    By jmatus86 in forum AutoCAD 3D Modelling & Rendering
    Last Post: 16th May 2011, 01:56 pm
  4. "AutoCad has stopped working" message
    By airrace in forum AutoCAD General
    Last Post: 27th Feb 2010, 05:15 pm
  5. After command 'copy': "Autocad message: item added" WHY?
    By MarcoW in forum AutoLISP, Visual LISP & DCL
    Last Post: 25th Aug 2009, 12:24 pm
