The difference between autocad 2000 and autocad 2010
bosch
  • Replies 26
  • ReMark
    5
  • rkent
    5
  • Tuns
    3
  • tzframpton
    2
Posted Images
Well, to see the differences up to the latest version, download the trial version from Autodesks homepage and see for yourself. So much has happened that I don't think anyone can list it all.
Now, if the question is 'Can I go from 2000 to 2010 and still feel at home and produce drawings?'
Hard question, depends on if you want to do it mostly I'd say.
A partial list...
The "Ribbon" including Tabs and Panels.
Dynamic blocks.
External references.
Improved performance.
Hatch improvements.
Publishing.
3D enhancements.
New commands added.
Constraints/parametrics.
Annotative scaling of hatches, text, linetypes, etc.
Multileaders.
Want more?
The CUI.
Hyperlinks.
Contextual MTEXT.
Tables.
The QAT.
eTransmit.
Tool palettes.
Loft command.
NAV wheel.
Mesh modeling.
The "Gizmo".
Convert to Solid.
Convert to Surface.
Send to 3D printer.
Layer translator.
Sectionplane.
Scalelists.
Sheet set manager.
Action recorder.
Fields.
Datalinks.
CAD standards checker.
Page setup manager.
AutoDesk Seek.
The CommCenter.
I haven't lost you yet have I? LoL
Will you be requiring detailed information on each of the above next?
Edited by ReMark
The differents between autocad 2000 and autocad 2010
Here are some of the highlights, by no means is the list comprehensive.
2000i-
trim to objects within blocks
fillet anc chamfer multiple polylines
enhanced rectang command
plot merged lines in most plot device drivers
new file open and navigation dialog
2002-
associative dimensioning
block attribute manager
layer previous
enhanced spell checking
2004-
express tools
gradient hatch fills
mtext enhancements
true color and color book support
match properties enhancements
xopen command, xref notification, xref multiple files at once
EDU drawing warning
qnew command allows setup of template to be used
publish multiple drawings at once
2005-
field text
sheet set manager
tables
draworder
texttofront
layer manager adds filter tree
mtext suports fields, color background
hatches can be trimmed
background plotting
copy command defaults to multiple
2006-
dynamic input
enhanced grips
CUI
dimension flip arrows
create separate hatches
hatch editing enhanced
join command copy undo option added
fillet and chamfer zero radius with shift key
offset command enhancements
trim and extend toggle with shift key
mtext editor is WYSIWYG
mtext supports formatting using bullets, numbers, alpha
drawing recovery manager
temp override keys added
scalelistedit
command line hidden with CTRL+9
quickcalc
autocomplete at command line
2007-
3D modeling - helix, loft, polysolid, pyramid, sweep
3D editing - presspull, imprint, sectionplance, flatshot
3D viewing- 3dforbit, 3dmove, 3drotate, chspace
xref palette
DUCS added to status bar
fields - added autolisp variables
slice with surface object
2008-
Annotation property
Multiline Leaders - MLeaderStyle, MLeaderAlign, MLeaderCollect, MLeaderEdit, AiMLeaderEditAdd
Layer Dimming and Layout Overrides
Dimensions - DimBreak, DimInspect, DimJogLine, DimSpace
DimArc extension line, DimAng Quadrant option
Dynamic blocks - displays tooltips with the purpose of grips
CopyMode system variable
new LayLockFadeCtl system variable
LayIso command can lock and fade instead of freezing
Mtext - annotative scaling, column wrapping, and spacing between paragraphs.
Xclip adds invert option
2009-
Ribbon
Layers dialog into a palette (ClassicLayer command added)
Quick Properties
Quick Views
Ribbon (dashboard removed)
ExportLayout
GenerateSection
Big Red A application menu, QAT quick access toolbar
rollover tips
extended tooltips
spell check - real time checking
2010-
2D parametrics - Geometric and Dimensional Constraints
Super commands - Attach, Adjust, Clip, MeasureGeom, Ulayers, TextEdit
MeasureGeom
segment editing - hold down Ctrl during scale, rotate, move
SECTIONPLANE, SECTIONPLANEJOG, SECTIONPLANETOBLOCK, SECTIONPLANESETTINGS
Parameters Manager
mtext grips added triangle grips for editing
2011 -
Grid - lines in 2D
Ribbon updates, added 3D Basic WS
Grip added to polyline
Selection cycling enhancement - SC toggle at bottom of screen
Multifunctional grips
SelectSimilar command added, HideObjects, Unhide,
AddSelected command added
HideObjects command added
IsolateObjects, UnisolateObjects
3D object snaps
2012 -
Autocomplete command
VpControl viewport controls - navigation, views and visual styles on screen
Ribbon sizing - three minimized settings
mtext background remembers last used fill color and offset
grip with lengthen option
grips are multi-functional for more objects - arcs, assoc arrays, dims, elliptical arcs, lines, mleaders, 3d faces edges vertices
Associative Arrays, grips editing
Blend - connects two objects using a spline
Extend works with Splines, Fillet works with Splines
Support for multiple paths for PMP, PC3, CTB, STB files
Snap can be set to work only while in a command, SnapMode sysvar
Drawing Views - 2D drawing views from 3D model and 1st or 3rd angle projection Base View
3D editing - ChamferEdge and FilletEdge added Loop option
3D editing - OffsetEdge
MeshCap has options added
Point Clouds enhanced
2013 -
drawing views additions, create details and sections
Properties - shows realtime previews for colors, lineweights, lintypes, transparency, layers
Array - displays contextual tab, uses default values to show instant previews
Offset has preview before picking
Polylines - reversed plines with varying widths handled with new sysvar PlineReverseWidths
2014-
command line - spell checking, synonyms, block names, layer names, hatch name, visual styles, dim style
autocorrect - after three misspellings the word is added
type at command line to change layer, text style, dim style, visual style
type at command line with hatch name to start hatch command
type at the command line with a block name and the insert command will start
mid string search at command line
Drawing Tabs - tabs displayed for each drawing
Chamfer command closes polylines
Filleting polylines will close polylines
Layers - merge selected layers in layer manager (LAYERDLGMODE must equal 1)
Xref layer names are not shown in the properties palette
Xrefs can be selected in quantities and the path or xref type changed in-mass
Surely you jest when you say "by no means is the list comprehensive"?
Your list details everything my list jumped over! :lol:
Now you have gone and really scared the OP.
There is a lot more than that to each release, those are the highlights for me. Going from 2000 to 2014 is a huge jump and I would imagine plotting would be the biggest challenge otherwise it is still just lines and circles.
The OP just decided not to upgrade as it will be time to retire before he learns all the new stuff. LoL
ReMark and everyone - I think we should come up with a list of the biggest developments of AutoCAD for the past releases, say r13 to today. This might include things we don't like (Ribbon for some) or things we don't make use of (3D for some).
I haven't thought about it a lot but off the top of my head I would nominate:
Ribbon
Properties
Mtext
3D enhancements (I will have to get more specific)
Tool palettes
Annotative properties
multiple layouts
Anyone want to add to the list?
I might take a shot at it when I have a moment.
Boy guys (ReMark and others) that is a mamoth Task.
But where is the OP? Perhaps he is already in hospital suffering from a heart attack. I had never realised that so much had happened!
OP? We don't really care about the OP in any thread, other than for them to provide a topic for us to beat to death.:lol: :twisted:
You should put a disclaimer there saying, "No actual animals were harmed in the making of this photo." Also I really like the addition of the CUI to AutoCAD... Mostly because I'm on LT but it is very nice to have none the less.
Ribbon
Properties
Mtext
Tool palettes
multiple layouts
Some key added items to your list off the top of my head:
2D:
Dynamic Blocks
Tables
Multileaders
Sheet Set Manager
3D:
Mental Ray rendering engine
Photometric Lighting
Parametric Solids
Materials
  • 1 year later...
Ribbon
Properties
Mtext
Tool palettes
multiple layouts
If you are drawing in 2D there in no big difference between 2000 and 2010. AutoCad 2000 support Vlisp, so you can make anything for 2D drawing.
... and there's no big difference between these two versions either because you can make calls with either :roll:
