Results 1 to 8 of 8
Thread: Draw rectangle
    Full Member
    spiker7221's Computer Details
    Windows 7 Pro 64
    Dell T3600
    20 gig
    nVidia Quadro 4000
    AutoCAD 2014
    Mar 2013
    73
    Question Draw rectangle
    Learning how POLAR works by creating a rectangle at offset points from the midpoint of a line. It works sometimes depending on the rotation of the line selected. LtoR seems to work, but RtoL is off a bit. I'm pretty sure I need some sort of COND statement like...
    Code:
    (if (and (>= entrot 0.0) (<= entrot 90.0))
    Here's what I've come up with so far...
    Code:
    (defun C:drawbox (/)
        (defun dtr (a)
          (/ (* a 180.0) pi)
            (setq ent (car (entsel)))
            (setq entlay (cdr (assoc 8 (entget ent))))
            (setq opt1 (cdr (assoc 10 (entget ent))))
            (setq opt2 (cdr (assoc 11 (entget ent))))
            (setq ang1 (angle opt1 opt2))
            (setq fang (dtr ang1))
            (setq tmpt (/ (distance opt1 opt2) 2.0))
            (setq mpt (polar opt1 ang1 tmpt))
        );end progn
            (setq d6 18.0)
            (setq a6 5.0)
            (setq npt6 (polar mpt (- fang a6) d6))
            (command "text" npt6 "2.0" fang "6")
            (setq d7 16.0)
            (setq a7 14.0)
            (setq npt7 (polar mpt (- fang a7) d7))
            (command "text" npt7 "2.0" fang "7")
            (setq d8 18.0)
            (setq a8 7.0)
            (setq npt8 (polar mpt (- fang a8) d8))
            (command "text" npt8 "2.0" fang "8")
            (setq d9 18.0)
            (setq a9 14)
            (setq npt9 (polar mpt (+ fang a9) d9))
            (command "text" npt9 "2.0" fang "9")
            (command "pline" npt8 npt9 npt6 npt7 "c")
        );end progn
    Thanks for any help,
    Mike
    Senior Member
    Mechanical
    jdiala's Discipline Details
    Cad Manager
    Mechanical
    AutoCAD 2014
    Jul 2013
    Fairfax, VA
    100
    Try this but without the text. Change some variables -> less typing.
    Code:
    (defun C:drawbox (/ e lay p1 p2 a mid d l w npt1 npt2 npt3 npt4 )
    (setq e   (car (entsel))
          lay  (cdr (assoc 8 (entget e))) ;; not needed
          p1   (cdr (assoc 10 (entget e)))
          p2   (cdr (assoc 11 (entget e)))
          a    (angle p1 p2)
          mid  (mapcar '(lambda (a b ) (/ (+ a b ) 2.)) p1 p2)
          l    (distance p1 p2)
          w    10 ;;; width of rectangle
          npt1 (polar (polar mid (+ a (/ pi 2.)) (/ w 2. ))	(+ a pi) (/ l 2.))
          npt2 (polar npt1 (+ a (* pi 1.5)) w)
          npt3 (polar npt2 a l)
          npt4 (polar npt3 (+ a (/ pi 2.)) w)
    (command "_.pline" "_non" npt1 "_non" npt2 "_non" npt3 "_non" npt4 "c")
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,587
    A simple fix but it needs your co-operation you don't pick near mid rather always what you want as near left end this way it will always create the rectang on the correct side. Even upside down. This is an oldie pretty sure there is a shorter VL lisp version.
    Code:
    (defun sel_obj ()
      (SETQ TP1 (entsel "\nSelect inside wall near left end: "))
      (setq tpp1 (entget (car tp1)))
      (setq clay (cdr (assoc 8 tpp1)))
      (setq p1 (cdr (assoc 10 tpp1)))
      (setq p2 (cdr (assoc 11 tpp1)))
      (setq p3 (cadr tp1))
      (setq ht (cdr (assoc 40 tpp1)))
      (setq el (caddr p1))
      (setq d1 (distance p1 p3))
      (setq d2 (distance p2 p3))
        (if (> d1 d2)
        (setq temp p1)
        (setq p1 p2)
        (setq p2 temp)
        (setq ang (angle p1 p2))
      (setq ang1 (+ ang 1.5708))
    (sel_obj)
    Forum Deity David Bethel's Avatar
    Multi-disciplinary
    David Bethel's Discipline Details
    Multi-disciplinary
    Commercial Food Service
    AutoCAD pre 2000
    Dec 2003
    Newport News, Virginia
    2,547
    a couple things jump out
    Code:
    (angle) returns radians
    no further conversions are needed
    As an aside, the (dtr) call you have is really a RadianToAngle conversion
    Code:
    (defun AtoR (a) (* pi (/ a 180.0)))            ;Angle To Radian
    (defun RtoA (r) (/ (* r 180.0) pi))            ;Radian To Angle
    A (polar) call required the angle in radians.
    -David
    R12 (Dos) - A2K
  5. #5
    Senior Member
    Mechanical
    Cad Manager
    Mechanical
    AutoCAD 2014
    Jul 2013
    Fairfax, VA
    100
    Here is a nice tutorial in regards with polar function.
    http://www.afralisp.net/autolisp/tut...ics-part-3.php
  6. #6
    Full Member
    Windows 7 Pro 64
    Dell T3600
    20 gig
    nVidia Quadro 4000
    AutoCAD 2014
    Mar 2013
    73
    Default draw box
    Good morning/afternoon JDiala,
    Here's your modified code to work for my scenerio..
    Code:
                (setq entmpt (mapcar '(lambda (ang1 b ) (/ (+ ang1 b ) 2.)) pt1a pt2a))
                (setq npt6 (polar (polar entmpt (+ ang1 (/ pi 2.)) (/ w 2.0 ))    (+ ang1 pi) (/ l 2.)))
                (setq npt7 (polar npt6 (+ ang1 (* pi 1.5)) w))
                (setq npt8 (polar npt7 ang1 l))
                (setq npt9 (polar npt8 (+ ang1 (/ pi 2.)) w))
    ;........................ capture text ...................................
                (setq entxt (ssget "_WP" (list npt8 npt9 npt6 npt7)
                            '((0 . "TEXT") (8 . "A-ANNO*"))
                            );end ssget
                );end setq
    It works great...if my lines are drawn from left to right. I know how to capture for the entity rotation, but how do I flip the rectangle calculation to flip as well?
    Thanks,
    Mike
    Quote Originally Posted by jdiala View Post
    Code:
          a    (angle p1 p2)
          l    (distance p1 p2)
    Senior Member
    Mechanical
    Cad Manager
    Mechanical
    AutoCAD 2014
    Jul 2013
    Fairfax, VA
    100
    Can you post a picture on what you are trying to do. Where do you want your first point? will it clockwise or counter clockwise?
  8. #8
    Senior Member
    Mechanical
    Cad Manager
    Mechanical
    AutoCAD 2014
    Jul 2013
    Fairfax, VA
    100
    Quote Originally Posted by spiker7221 View Post
    Like this:
    Code:
          a    (LM:MakeReadable (angle p1 p2))
          l    (distance p1 p2)
     (setq entxt (ssget "_CP" (list npt1 npt2 npt3 npt4)
                            );end ssget
    ;;  Author: Lee Mac, Copyright © 2011 - www.lee-mac.com       ;;
    (defun LM:MakeReadable ( a )
      ((lambda ( a )
          (cond
            ( (and (> a (/ pi 2)) (<= a pi)) (- a pi))
            ( (and (> a pi) (<= a (/ (* 3 pi) 2))) (+ a pi))
            ( a )
        (rem a (* 2 pi))
  1. Draw Rectangle Dimension
    By nejadarea in forum AutoLISP, Visual LISP & DCL
    Last Post: 18th Apr 2013, 04:39 pm
  2. Draw a rectangle on a Block
    By rodrigo_sjc_sp in forum AutoLISP, Visual LISP & DCL
    Last Post: 8th Apr 2013, 02:38 pm
  3. Draw a circle centered in a rectangle
    By AutoCAD Tips Blog in forum AutoCAD RSS Feeds
    Last Post: 17th Jan 2012, 03:50 am
  4. How to accurately draw a rectangle ?
    By JamFam in forum AutoCAD Beginners' Area
    Last Post: 11th Apr 2006, 07:47 pm
  5. Draw Rectangle by Area
    By Brunello19 in forum AutoLISP, Visual LISP & DCL
    Last Post: 9th Nov 2005, 04:50 am
