adrath Posted August 28, 2013 Share Posted August 28, 2013 I recently got an upgraded computer at work, with AutoCAD 2013 installed. I also have Civil 3D 2013 and AutoCAD 2012. Here is the problem that I am having, and it only happens in AutoCAD 2013. All of the other versions I have are fine: when I type a command Alias (like 'l' for line or 'm' for move) AutoCAD tells me that it doesn't recognize the command. I can, however, key-type the entire command and it will recognize that. So...I used "Aliasedit" to check my command aliases. A dialogue box came up asking me to find the .pgp file, which I did (and it was in the correct place). I hit apply and it tells me that the .pgp file has been updated. But the aliases still will not work. I tried a reinit, and comes back with the message "dialogs are not available because DCL files are not loaded." I tried typing (findfile "acad.pgp") and AutoCAD just returns "nil" as the result. I also tried (load "acad") and (load "adt") because I saw these in an AUGI forum where someone was describing a similar issue. Neither of these worked. Finally, I had IT uninstall and re-install AutoCAD last night. When I went to test it out this morning, I am still having the same issue! Has anyone ever encountered something like this before? Any ideas on what might be causing it/how I might be able to fix it? Quote Link to comment Share on other sites More sharing options...
adrath Posted August 28, 2013 Author Share Posted August 28, 2013 Nevermind. The problem has been resolved. Apparently, it had something to do with the fact that IT installed AutoCAD 2013 from a profile other than mine. We tried another re-install with shared control of my computer under my profile and it works just fine now. Quote Link to comment Share on other sites More sharing options...
