Page 1 of 2 1 2 LastLast
Results 1 to 10 of 16
    Junior Member LINHOREKA's Avatar
    AutoCAD 2008
    Feb 2009
    23
    Default Lisp create perspective view from a 2D drawing
    Hi, this lisp is working in 2D only: it generate a perspective view from a selected 2D plan or elevation.
    1. Command: P2D
    2. Select the source frame (trapezoid polyline) of the plan or elevation
    3. Select drawing objects in that source plan or elevation
    4. Select destination frame >>> a new perspective drawing would be draw arcordingly (see image and example drawing)
    5. Repeat step 4 until you select none
    It is working only with straight lines, straight polylines and points. Pretty useful when you want to take a leap up from your 2D, for but donot have time to create a 3D model.
    New version on Apps Exchange Store, extrusion enabled
    Last edited by LINHOREKA; 8th Oct 2013 at 06:03 am. Reason: Update link of new version
    Lee Mac's Computer Details
    Win 7 Pro / Win 10 Pro / Linux Mint
    Multi-disciplinary
    Lee Mac's Discipline Details
    Multi-disciplinary
    AutoCAD 2018
    Aug 2008
    London, England
    19,501
    Thank you for sharing your program LINHOREKA
    To provide some food for thought, you might be interested in this outstanding program by Sean Tessier
    Lee Mac ProgrammingTwitterExchange App StoreDropbox (500MB free)
    AutoCAD 2008
    Feb 2009
    23
    Wow, with Sean Tessier, we can make 3D street art !
    There is another kind of simple perspective 2D like this: A profile + 1 vanishing point = This image (from CAD APLUS)
    Senior Member nod684's Avatar
    nod684's Computer Details
    Windows 7 Home
    Architectural
    AutoCAD 2014
    Jul 2012
    Philippines
    345
    nice one! does this work for blocks too?
    "Memories fade but the scars still linger...."
  5. #5
    AutoCAD 2008
    Feb 2009
    23
    No, it works only with elementary objects of straight lines and polylines. Try lisp suggested by Lee Mac, works with curves, hatches. But no block avaiable neither !
    I found my lisp has an advantage: it can transform from any trapezoid frames to any others.
    I test to make 3D street arts and here it is:
    1. If objects lay inside the frame polylines, it is ok
    2. If objects lay outside, it fails (not yet understand why )
    Anyway, it is interesting. Someday I would upgrade it to work with all objects, and correct this trouble.
  6. #6
    AutoCAD 2008
    Feb 2009
    23
    Ah, i work it out: the objects cannot go too high over the horizontal sky line !
    Here is another example shows how it work well enough:
    It implies 3D street art need alot of area if draw objects extrude up, but less area if draw objects extrude down ! That is why valley is prefered, while moutains is not
  7. #7
    Forum Deity SEANT's Avatar
    AutoCAD 2014
    Aug 2005
    Rhode Island
    2,463
    Hey guys, thanks for the mention. Perspective transform is an interesting field.
    From what I can see, LINHOREKA, we both used a similar process, as did maicy in the links below. The alternative is straight matrix manipulation as demoed by SOFITO_SOFT and Kean (Through the Interface).
    The links here show some interesting variations on the theme. Those for theswamp.org will require registration. It is such a good site, though, any AutoCAD developer would be happy they made the effort.
    http://www.theswamp.org/index.php?topic=36905.0
    http://www.theswamp.org/index.php?topic=37183.0
    http://through-the-interface.typepad.com/through_the_interface/2013/08/applications-for-linear-algebra-straightening-out-perspective.html
    http://through-the-interface.typepad.com/through_the_interface/2013/08/update-on-the-project-to-de-skew-images-inside-autocad.html
    http://through-the-interface.typepad.com/through_the_interface/2013/08/generating-png-files-for-de-skewed-portions-of-perspective-images.html
  8. #8
    AutoCAD 2008
    Feb 2009
    23
    Hi everyone, new version is coming :
    (but not yet )
  9. #9
    AutoCAD 2008
    Feb 2009
    23
    Hi, New Version on AutoCAD Exchange Store: Your 2D Perspective
    New Feature: Extrusion ! It is now quite handy for drafters who want to add some 3D views in technical drawings, but too lazy (like me) to try managing the 3D Model stuff.
  10. #10
    AutoCAD 2014
    Aug 2005
    Rhode Island
    2,463
    This looks excellent. Very impressive. And congratulations on your Exchange listing.
  1. Perspective View - Can't get consistant view of small objects
    By numberOCD in forum AutoCAD 3D Modelling & Rendering
    Last Post: 21st Sep 2010, 02:45 pm
  2. Perspective view
    By spursnutter in forum AutoCAD 3D Modelling & Rendering
    Last Post: 18th Dec 2008, 01:06 am
  3. Perspective View?
    By JaketheMan in forum AutoCAD General
    Last Post: 13th Aug 2007, 05:57 pm
  4. perspective view
    By Icarus in forum AutoCAD General
    Last Post: 12th May 2006, 07:49 pm
  5. perspective view
    By richierich in forum AutoCAD Beginners' Area
    Last Post: 2nd Nov 2004, 08:06 pm
Tags for this Thread
