Results 1 to 4 of 4
    Forum Newbie
    Mechanical 2012
    Jul 2013
    6
    Default change viewports position (x and y cordinates)
    Hello every one,
    i found thread about change height and width of particular one viewport.
    My current situation:
    I have 3 viewports.
    i want only one viewport at some specific coordinate (say x=100, y=200)
    and remain two viewports are are at other coordinate (say x=1000, y=2000)
    it is possible manually, by simply selecting 1st viewport and editing "Center X" and "Center Y" of their viewport property.
    if some one know than please help me...
    Alok
    Lee Mac's Computer Details
    Win 7 Pro / Win 10 Pro / Linux Mint
    Multi-disciplinary
    Lee Mac's Discipline Details
    Multi-disciplinary
    AutoCAD 2018
    Aug 2008
    London, England
    19,501
    Welcome to CADTutor Alok
    Are you referring to the viewport target (i.e. the objects viewed through the viewport), or the position of the viewport object itself in paperspace?
    If you are referring to the target, you will first need to store the current viewport scale (customscale property) so that it may be reset later; you will then need to activate the viewport (mspace property) and set it as the active paperspace viewport (activeviewport property).
    To change the target, you could use the zoomcenter method with an arbitrary scale factor (since the viewport scale can be restored later by the program). The stored viewport scale can then be reinstated via the customscale property and the viewport deactivated using the mspace property.
    Lee Mac ProgrammingTwitterExchange App StoreDropbox (500MB free)
    Forum Newbie
    Mechanical 2012
    Jul 2013
    6
    Thanks alot Lee,
    For your instance reply.
    But i am not that much familiar about VBA programming.
    as i was go throug lots of treadds in CADTutor i just have some idea.
    following code is working well for setting desire target(x,y) , scale, height and width.
    Sub PVPortManipulation()
    'Iterate through the viewports of every paperspace Layout.
    'Change the pviewports height to 6
    'Change it to SE Iso view
    'Move each paperspace vport 2 units to the right.
    'Set vport scale
    'Modify target
    Dim Entity As AcadEntity
    Dim VPcenter As Variant
    Dim PVport As AcadPViewport
    Dim objLayout As AcadLayout
    Dim dblDir(0 To 2) As Double
    Dim i As Integer
    For Each objLayout In ThisDrawing.Layouts
    If objLayout.Name <> "Model" Then
    ThisDrawing.ActiveLayout = objLayout
    ThisDrawing.MSpace = False
    For i = 1 To objLayout.Block.Count - 1 'avoid primary Paperspace PViewport
    Set Entity = objLayout.Block.Item(i)
    If TypeOf Entity Is AcadPViewport Then
    Set PVport = Entity
    PVport.Display True
    PVport.Height = 10
    PVport.Width = 50
    dblDir(0) = -1#: dblDir(1) = -1#: dblDir(2) = 1#:
    PVport.Direction = dblDir
    VPcenter = PVport.Center
    VPcenter(0) = 100#
    VPcenter(1) = -50#
    PVport.Center = VPcenter
    PVport.StandardScale = acVp1_10
    dblDir(0) = -6
    PVport.Target = dblDir
    PVport.Update
    End If
    Next
    ThisDrawing.Regen acAllViewports
    End If
    Next
    End Sub
    but how i will set different viewports property.
    above code is working, but it is changing all viewport target and all other properties to the same.
    Thanks.
    Alok
    Forum Newbie
    Mechanical 2012
    Jul 2013
    6
    Is it possible????
    it will help me alot...
  1. Cant paste by cordinates
    By Bara in forum AutoCAD Beginners' Area
    Last Post: 18th Jan 2013, 12:48 pm
  2. Change position of attributes
    By Mica in forum AutoCAD Drawing Management & Output
    Last Post: 10th Apr 2012, 07:29 am
  3. Loosing unwrap UVW cordinates
    By nowikovs12 in forum UVW Mapping, Textures & Materials
    Last Post: 7th Mar 2012, 11:32 am
  4. How to change the position of an object without changing the ucs?
    By marlon in forum AutoCAD 3D Modelling & Rendering
    Last Post: 5th Nov 2008, 05:57 am
  5. Change in Viewports
    By Wicks in forum AutoCAD General
    Last Post: 2nd Jan 2008, 08:19 pm
Tags for this Thread
