Results 1 to 5 of 5
    Full Member
    not specified
    Jan 2006
    brooklyn, ny
    56
    Default "flatten" 3d to 2d?
    We have an automation program here that creates 3d models of rooms. However, the files come out to be very large, at up to 50 meg, and we're having a few problems in connection to that, i.e. they're hard to work with in Acad, take a long time to load, save, modify and often we need to email to people and that takes too long and sometimes they don't accept that size. We can do something about the latter issue using various workarounds but not about first issue, i.e. these files are very bulky to work with. So, it seems like there must be a way to flatten a 3d file into a 2d, most importantly hiding, or erasing the lines that should not be visible because they're behind some object. I think there must be a freebie or a fairly cheap program or lisp macro that would do that, do you guys know of anything that has such functionality? Thanks!
    p.s. I thought about, and tried exploding everything and erasing unneeded lines. That works fine except that obviously it takes sometimes more time than it's worth.
    Luminous Being tzframpton's Avatar
    tzframpton's Computer Details
    HP Zbook
    Multi-disciplinary
    tzframpton's Discipline Details
    BIM Specialist
    Multi-disciplinary
    Full Virtual Design and Construction BIM services for the MEP engineering and construction industries.
    Revit 2019
    Mar 2006
    Dallas, TX - USA
    9,115
    Tannar Z. Frampton ™ | Frampton & Associates, Inc.
    Full Member
    AutoCAD 2007
    Apr 2006
    Phoenix, AZ
    92
    There's also the Flatten command in the Express Tools if you're using a newer version.
    Dan - Phoenix, AZ
    As seen in Four Wheeler Magazine - October, 2006.
    Acad2k7, WinXP, HVE, Rhino3.0
    Full Member
    not specified
    Jan 2006
    brooklyn, ny
    56
    Default Thanks!
    Thanks Styk & FindAFace..
    It works out just great, and everyone was very impressed that I "figured out a way", 'cause our main Acad programmer said it's impossible & cannot be done, and Autocad support people also said it's impossible. Now I'm considered to be something in between a genius and an enigma.
    There's only one minor issue in that it messes up text, breaking it up and simplifying it. But that's not a problem for us 'cause all text coming out of the program is on a separate layer. Neato! I should have searched the forum for that...
  5. #5
    Junior Member
    not specified
    Jul 2006
    16
    Default 50 meg of 3D?
    what automation prog is that? better have a look around for something else, it sounds like it's from the Stone Age.
