ReMark Posted September 5, 2013 Share Posted September 5, 2013 This came to my attention as a result of Ralph Grabowski's upFront.eZine NEWS #788 (dated August 27, 2013) found an exploit in files used by AutoCAD 2007 and later (plus associated verticals) as well as DWG Trueview. AutoDesk "quietly" released a hotfix that addresses the problem but strangely enough it works only for versions 2011 thru 2014. Anyone else beside me hear of or read this then download and install the hotfix? The hotfix can be found here... http://usa.autodesk.com/adsk/servlet/ps/dl/item?id=21972896&linkID=9240618&siteID=123112 Quote Link to comment Share on other sites More sharing options...
neophoible Posted September 5, 2013 Share Posted September 5, 2013 This came to my attention as a result of Ralph Grabowski's upFront.eZine NEWS #788 (dated August 27, 2013) found an exploit in files used by AutoCAD 2007 and later (plus associated verticals) as well as DWG Trueview. AutoDesk "quietly" released a hotfix that addresses the problem but strangely enough it works only for versions 2011 thru 2014. Anyone else beside me hear of or read this then download and install the hotfix? The hotfix can be found here... http://usa.autodesk.com/adsk/servlet/ps/dl/item?id=21972896&linkID=9240618&siteID=123112 Thanks, ReMark. BTW, I'm not sure it's so strange that the hotfix only applies to 2011 thru 2014. Does Autodesk support any versions earlier than that now? If not, then I would not expect them to provide a hotfix for them, or even say if it works for them or not. Quote Link to comment Share on other sites More sharing options...
ReMark Posted September 5, 2013 Author Share Posted September 5, 2013 It does not apply to nor work for the 2007-2010 releases. Quote Link to comment Share on other sites More sharing options...
Dana W Posted September 5, 2013 Share Posted September 5, 2013 It does not apply to nor work for the 2007-2010 releases.Then when I get infected, I will email my complete copy of 2009 to Autodesk. Quote Link to comment Share on other sites More sharing options...
ReMark Posted September 5, 2013 Author Share Posted September 5, 2013 The perils of working without a net I suppose. One would think there are enough users out there to justify the effort required to protect them as well even if it only amounts to a 'good will' gesture. Quote Link to comment Share on other sites More sharing options...
neophoible Posted September 5, 2013 Share Posted September 5, 2013 The perils of working without a net I suppose. One would think there are enough users out there to justify the effort required to protect them as well even if it only amounts to a 'good will' gesture.Yes, but... I suspect that sort of thing would fly in the face of trying to manipulate users to pay to upgrade. Quote Link to comment Share on other sites More sharing options...
Dana W Posted September 6, 2013 Share Posted September 6, 2013 Yes, but... I suspect that sort of thing would fly in the face of trying to manipulate users to pay to upgrade.My license is just a little over 3 years old. One would think a little retro support combined with useful improvements in the new versions would go a long way to convince me to upgrade, wouldn't one. Quote Link to comment Share on other sites More sharing options...
neophoible Posted September 6, 2013 Share Posted September 6, 2013 My license is just a little over 3 years old. One would think a little retro support combined with useful improvements in the new versions would go a long way to convince me to upgrade, wouldn't one.Maybe in theory, but it seems to me some yogi addressed that quite poetically. You can probably find a quote to that effect somewhere around here if you look. For the devious it's far more fun to knock 'em to the mat, grind their face into it, twist 'em up like a pretzel till they scream in agony, then make 'em sign, broken fingers and all (I think they call it "handholding" as they guide you through the signature phase). At least that's what it feels like from here. Quote Link to comment Share on other sites More sharing options...
Dana W Posted September 6, 2013 Share Posted September 6, 2013 Maybe in theory, but it seems to me some yogi addressed that quite poetically. You can probably find a quote to that effect somewhere around here if you look. For the devious it's far more fun to knock 'em to the mat, grind their face into it, twist 'em up like a pretzel till they scream in agony, then make 'em sign, broken fingers and all (I think they call it "handholding" as they guide you through the signature phase). At least that's what it feels like from here. I think you just defined Autodesk's subscription program. Quote Link to comment Share on other sites More sharing options...
Dadgad Posted September 7, 2013 Share Posted September 7, 2013 I think you just defined Autodesk's subscription program. Whence the whole concept of planned obsolescence. Quote Link to comment Share on other sites More sharing options...
