Rotating lots of individual bits of text at once
Barneel
Gave a set of schematics to a client and they decided they wanted all the wire numbers rotating 90 degrees... In the interest of efficiency I thought I'd ask you guys if there is a way I can rotate all the pieces of text at the same time whilst maintaining their individual position rather than selecting a base rotation point (as I have about 400 wire numbers to make my way through :glare:).
Any Help?
[ATTACH=CONFIG]43882[/ATTACH]
Found a solution!
In case somebody finds this thread looking for an answer:
If you select all the pieces of text you need rotating and Right click -> Quick Properties, there will be a box in the properties titled "Rotation". Simply change the number in here to the desired rotation.
