Center of mass
byk3bep
I am wondering is there a command that can let me find the center of mass for a linear object.
In particular I need to find the center of mass for an arc.
Any suggestions would be appreciated :)
Thx for your help
Ensure you have a closed poyline, use the REGION command to create a region, then use the MASSPROP command and it will give you the coordinates of your centroid, your moment of inertia etc.
Of course not :)
Doing master thesis...
I's for positioning the lifting straps for an arch segment made out of laminated wood. Here is a pic of the final position and the dimensions (units are in cm) so u might get a better idea. Cross section is 20/120cm...
All ideas and suggestions are appreciated :)
