Polyline display error
SAFeSTeR
Hi,
Earlier today I was joining some polylines and during the command AutoCAD temporarily froze. After a short time it resumed and I completed the task. However, after this some other polylines which have a thickness applied took on a 'wire-framed' appearance (see attached image where one of these lines has been selected).
Now, I've had this happen before, but always been able to easily fix it with a regen or re-launch of the file or AutoCAD itself, but now that is not working. I even rebooted my PC but this did not help.
It seems this only affects the file I was working on, an older copy of the file displays the same lines as normal.
So, has anyone encountered this and is there a 'fix'?
"Custom View" (top left)
Fillmode only works when viewing the polyline in plan view. Most likely you just need to reset the PLAN view
That's it, it's fixed! Don't know how that got changed :? must have clicked on it by accident during the initial polyline edit.
Thanks nestly :)
