Page 1 of 7 1 2 3 ... LastLast
Results 1 to 10 of 69
    Full Member
    Mir Ali's Computer Details
    HP DV6000 Laptop
    AutoCAD 2012
    Sep 2012
    39
    Default Making leaf-like city layout plan
    Hi everyone !
    I am designing a city with leaf-like layout. I've across a problem in the very beginning which is that i can't seem to understand the geometry involved in here. Let's i want to make a leaf shaped town such that it can have any desired area e.g. 800 acre with the same dimension like the leaf that added below. While experimenting with arc tool I've so far been able to do it but i would like to know the exact ways to do it. (pardon my English)
    Forum Deity
    AutoCAD 2002
    Sep 2006
    East Sussex, U.K.
    4,146
    Have you tried to insert the leaf picture into a drawing, and then trace over it?
    Inventor 2015
    Sep 2007
    Williamsport, PA
    8,731
    You will need more than one arc on each side or perhaps an arc and ellipse or a spline to reproduce the curve.
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,877
    The rough outline of the leaf can be generated by tracing over an edge using a polyline then miroring that polyline to the other side. The leaf is rather small though. You would have to scale it up considerably to approximate an area of 800 acres.
  5. #5
    Super Member
    AutoCAD 2012
    Jun 2012
    902
    If you keep it fairly simple, as in your OP, then the formula for the area of a segment is all you need (and double it for the two segments). Consider the formulae and approach offered in this link: http://www.regentsprep.org/Regents/m...cleSectors.htm. If you want to duplicate the actual shape of the leaf, then that will be a bit more complicated. It is quite easy to get the area of a polyline. You did not indicate how experienced you are with AutoCAD. If you are designing a city, I would hope you are very experienced. Or is this perhaps a school project?
    When all you have is a hammer, everything looks like a nail.--
    “Doc, it hurts when I do this.” “Well, don’t do that!”
    “Well, if you don’t know, I’m certainly not going to tell you!”
  6. #6
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,877
    1.25 square miles = 800 acres. You town won't be very big.
  7. #7
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,877
    This leaf like shape was created using four arcs that were then joined via the PEDIT command and mirrored.
  8. #8
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,877
    Mir Ali: So, have you made any progress?
  9. #9
    Full Member
    HP DV6000 Laptop
    AutoCAD 2012
    Sep 2012
    39
    so kind of you. Pardon me i may sound like real nuisance to you as i am really inexperienced with drafting . I've traced the picture and it gives me a nice layout. There are a few more things that i would like to know:
    1. Lets the traced figure has an area of 2000 sq.ft. How do i scale it get any desired area? I can do the units conversions
    2. How do i create the shape with arc tool by making four arcs?
    3. I am working in model space, hopefully i am going to print it on some scale. Do i have to work in viewports or should i carry on the work in model space and get it plotted. This is my first project that i am going to get plotted so i am unfamiliar with the paper sizes that i may get hands on.
    It's my university project and yeah the town size is quite small. But given the time and scope of the course i may design the project in around 800 acre to 1500 acre.
  10. #10
    Full Member
    HP DV6000 Laptop
    AutoCAD 2012
    Sep 2012
    39
    Quote Originally Posted by eldon View Post
    I guess that is what i have to go with.
    Quote Originally Posted by neophoible View Post
    Thanks but i am going to getting in technicalities though thank you. I have very little experience with AutoCAD probably used it a couple of times. I am studying city and regional planning and the course in which i've been given this practical is "Planning of new town"
  1. Office layout plan directory
    By BIGAL in forum AutoLISP, Visual LISP & DCL
    Last Post: 11th Aug 2012, 01:33 am
  2. Floor plan layout problem
    By MisterJingles in forum AutoCAD Beginners' Area
    Last Post: 13th May 2009, 11:19 am
  3. Making the Floor Plan less noticable
    By c0cl3c in forum AutoCAD Beginners' Area
    Last Post: 26th Mar 2009, 03:22 pm
  4. Where can Download restaurant layout plan (dwg)?
    By scottiegreen41 in forum AutoCAD General
    Last Post: 28th Jul 2008, 05:24 pm
  5. making a 3d model out of an archy plan
    By neyoski11 in forum AutoCAD General
    Last Post: 13th Dec 2007, 12:41 pm
