Page 2 of 7 FirstFirst 1 2 3 4 ... LastLast
Results 11 to 20 of 69
  1. #11
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,721
    You can use the SCALE command to increase/decrease the size of an object.
    I used the ARC command and roughly followed the outline I traced using the polyline command. It's a "trial and error" approach but no one is going to be checking you on how well you approximated the shape of a leaf.
    Draw all your geometry in model space at FULL size. Only when you are satisfied with the results and want to start adding text and/or dimensions do you have to give any real thought as to what goes where. They can go in either model space or in your layout. Each has its own pluses and minuses.
    Using a layout means you'll be using one or more viewports. It is the viewport that a scale is assigned to. I can provide you with a link with more information about viewports if you wish.
  2. #12
    Full Member
    Mir Ali's Computer Details
    HP DV6000 Laptop
    AutoCAD 2012
    Sep 2012
    39
    Yes sir please i would like to know more about the tools and tricks that i have to go through. Kindly do share the links.
  3. #13
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,721
    Viewports and Setting Scale thread can be found here...
    http://www.cadtutor.net/forum/showth...ight=viewports
  4. #14
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,721
    Mir Ali: Making any progress?
  5. #15
    Full Member
    HP DV6000 Laptop
    AutoCAD 2012
    Sep 2012
    39
    I've traced with the image and it has an area of 45 sq.ft. Lets i want to take it to 1500 acres (65,340,000sq.ft), so i tried this 45x= 65,340,000sq.ft gives me 1452000 and i tried scaling to this number but no use. I maybe able to get to the desired area but i want to learn how the scaling works in AutoCAD.
    I am working on 1 to 1 annotative scale. Thanks !
  6. #16
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,721
    You scaled your leaf using that number (1452000) but you did not get the result you were looking for?
    Annotative scaling is going to affect how your linetypes look in your layout and is normally applied to your text, dimensions, hatches, blocks, and multileaders.
  7. #17
    Full Member
    HP DV6000 Laptop
    AutoCAD 2012
    Sep 2012
    39
    Yes i scaled with 1452000 but it won't work. I tried putting ' and ".
    Should i go on working in model space or do have to make sure of some other certain things. Like i want to finish my work ASAP then move on the plotting part. Thank you sir !
  8. #18
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,721
    I don't see why it shouldn't work but your use of the word "and" has me wondering just how you are going about scaling your object.
    You continue to work in model space until you are satisfied you have everything completed. Given that you appear to want to use annotative scaling the only things that go in your layout would be a viewport along with your title block and border along with any title block text.
  9. #19
    Full Member
    HP DV6000 Laptop
    AutoCAD 2012
    Sep 2012
    39
    Maybe you want to see this...
  10. #20
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,721
    I'm not seeing a problem.
  1. Office layout plan directory
    By BIGAL in forum AutoLISP, Visual LISP & DCL
    Last Post: 11th Aug 2012, 01:33 am
  2. Floor plan layout problem
    By MisterJingles in forum AutoCAD Beginners' Area
    Last Post: 13th May 2009, 11:19 am
  3. Making the Floor Plan less noticable
    By c0cl3c in forum AutoCAD Beginners' Area
    Last Post: 26th Mar 2009, 03:22 pm
  4. Where can Download restaurant layout plan (dwg)?
    By scottiegreen41 in forum AutoCAD General
    Last Post: 28th Jul 2008, 05:24 pm
  5. making a 3d model out of an archy plan
    By neyoski11 in forum AutoCAD General
    Last Post: 13th Dec 2007, 12:41 pm
