Guest Posted September 13, 2013 Share Posted September 13, 2013 Is it posible to convert a *.txt file with coordinates to a table with coordinates with a lisp? coordinates.txt Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted September 13, 2013 Share Posted September 13, 2013 Try the attached program (txt2tab.lsp) txt2tab.lsp Quote Link to comment Share on other sites More sharing options...
Guest Posted September 13, 2013 Share Posted September 13, 2013 Nice lisp Mr Lee.If i need only (N,X,Y) what i need to do ? 1,309922.37,4242993.50 2,309928.18,4243002.99 3,309929.57,4243003.76 4,309930.81,4243004.45 5,309931.97,4243003.84 6,309933.59,4243003.00 7,309941.05,4242999.26 8,309946.61,4242996.29 9,309951.36,4242993.40 10,309954.93,4242991.36 11,309952.39,4242985.47 12,309949.97,4242979.80 13,309948.47,4242976.55 14,309948.03,4242976.72 15,309945.16,4242978.20 16,309944.86,4242978.41 17,309939.39,4242982.16 18,309937.52,4242983.45 19,309930.32,4242988.39 20,309925.14,4242991.84 Quote Link to comment Share on other sites More sharing options...
Guest Posted September 13, 2013 Share Posted September 13, 2013 I try to change this line (cons '("N" "X" "Y" "Z") (reverse lst)) whit this line (cons '("a/a" "X" "Y") (reverse lst)) but is not working !! Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted September 13, 2013 Share Posted September 13, 2013 Please try the attached updated program. The program parameters are found at the top of the code. Text2TableV1-1.lsp Quote Link to comment Share on other sites More sharing options...
Guest Posted September 13, 2013 Share Posted September 13, 2013 Thank you Mr Lee cheers Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted September 13, 2013 Share Posted September 13, 2013 You're welcome Prodromos. Quote Link to comment Share on other sites More sharing options...
shailujp Posted September 13, 2013 Share Posted September 13, 2013 Hi Lee, I have a similar request. Can you help me on this. I have been looking for something very similar what you have just posted. The only difference is that I have excel file instead of txt file. But that can be changed. Can my data be inserted as table just by specifying the excel file (or automatically detect the file name that I saved by this lisp) and insertion point rather than going via datalink and then table... Thanks in advance XYT21.lsp Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted September 13, 2013 Share Posted September 13, 2013 Hi shailujp, You could save your Excel file to a tab-delimited text file format, which could then be imported using the program I have posted in reply#5. Though, you would need to change the data delimiter parameter found at the top of the program source code from: del "," ;; Data Delimiter String to a tab character: del "\t" ;; Data Delimiter String I hope this helps! Quote Link to comment Share on other sites More sharing options...
shailujp Posted September 14, 2013 Share Posted September 14, 2013 Hi Lee, So I changed the lisp per what you explained. I also changed the following line so that it gives me 5 columns inserted vs just 3 per your original program. hdl '("Sr No" "X:" "Y:" "Dia:" "Type") ;; Table Headings Now, the issue is that I get two headings since I already have headings at the top of my data and again the "hdl" is again creating one more heading. I could not fix it. Also, how can this two lisp (yours and mine) be merged so when I run XYT21 lisp it creates the excel file and brings it in as a table (without having to locate the excel file)? Please excuse my inexperience but should there be only few lines on my lisp that just brings a datalinked table rather then the huge program? Something like "_.-table" and then look for the same file that my lisp creates and use the table format same as excel format via datalink? This is how I was planning and doing my trial and error before this post. I'm not sure which is a better option. Please guide. Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted November 12, 2013 Share Posted November 12, 2013 (edited) Why has my name been removed from all of my subfunctions? EDIT: I see that the post in question has now been removed, but I am still curious as to why you (prodromosm) would go to the trouble of removing my name from every function used in the program? Nevertheless, you will receive no more code from me prodromosm. Edited November 12, 2013 by Lee Mac Quote Link to comment Share on other sites More sharing options...
Guest Posted November 12, 2013 Share Posted November 12, 2013 Why has my name been removed from all of my subfunctions? EDIT: I see that the post in question has now been removed, but I am still curious as to why you (prodromosm) would go to the trouble of removing my name from every function used in the program? Nevertheless, you will receive no more code from me prodromosm. Lee I translate it to my language to understand it ........ok .It was a mistake of me sorry Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted November 12, 2013 Share Posted November 12, 2013 Lee I translate it to my language to understand it So why would the translation retain all other headings except my name? Quote Link to comment Share on other sites More sharing options...
Guest Posted November 12, 2013 Share Posted November 12, 2013 mistake of me. I am really sorry my friend Quote Link to comment Share on other sites More sharing options...
Tuns Posted November 12, 2013 Share Posted November 12, 2013 So why would the translation retain all other headings except my name? He probably did that so that the people he works with will think he wrote it and not you. That would be my guess at least because I see no plausible reason for ONLY your name to be removed. Quote Link to comment Share on other sites More sharing options...
Guest Posted November 12, 2013 Share Posted November 12, 2013 He probably did that so that the people he works with will think he wrote it and not you. That would be my guess at least because I see no plausible reason for ONLY your name to be removed. this is not true Quote Link to comment Share on other sites More sharing options...
Guest Posted November 13, 2013 Share Posted November 13, 2013 (edited) I want to add a command to give the text size , all the times have text size 4.5 and is too big ;; Text File to Table - Lee Mac ;; Prompts the user to select a text file containing 4 columns of comma-delimited data ;; and generates an AutoCAD Table containing the file data at the point specified. (defun c:txt2tab ( / *error* des ins lin lst txt ) (defun *error* ( msg ) (if (= 'file (type des)) (close des)) (if (not (wcmatch (strcase msg t) "*break,*cancel*,*exit*")) (princ (strcat "\nError: " msg)) ) (princ) ) (if (setq txt (getfiled "Επιλέξτε το αρχείο P,X,Y,Z (*.txt)" "" "txt" 16)) (if (setq des (open txt "r")) (progn (while (setq lin (read-line des)) (if (= 4 (length (setq lin (LM:str->lst lin ",")))) (setq lst (cons lin lst)) ) ) (setq des (close des)) (if lst (if (setq ins (getpoint "\nSpecify point for table: ")) (LM:addtable (vlax-get-property (vla-get-activedocument (vlax-get-acad-object)) (if (= 1 (getvar 'cvport)) 'paperspace 'modelspace ) ) (trans ins 1 0) nil (cons '("A/A" "X" "Y" "Z") (reverse lst)) nil ) ) (princ "\nNo valid data found in selected file.") ) ) (princ "\nUnable to open selected file for reading.") ) ) (princ) ) ;;---------------------=={ Add Table }==----------------------;; ;; ;; ;; Creates an AutoCAD Table Object at the specified point, ;; ;; populated with the given data and optional title. ;; ;;------------------------------------------------------------;; ;; Author: Lee Mac, Copyright © 2013 - [url]www.lee-mac.com[/url] ;; ;;------------------------------------------------------------;; ;; Arguments: ;; ;; spc - VLA Block Object ;; ;; ins - WCS Insertion Point for Table ;; ;; ttl - [Optional] Table title ;; ;; lst - Matrix list of data to populate the table ;; ;; eqc - If T, columns are of equal width ;; ;;------------------------------------------------------------;; ;; Returns: VLA Table Object ;; ;;------------------------------------------------------------;; (defun LM:AddTable ( spc ins ttl lst eqc / dif hgt i j obj stn sty wid ) (setq sty (vlax-ename->vla-object (cdr (assoc -1 (dictsearch (cdr (assoc -1 (dictsearch (namedobjdict) "acad_tablestyle") ) ) (getvar 'ctablestyle) ) ) ) ) ) (setq hgt (vla-gettextheight sty acdatarow)) (if (LM:Annotative-p (setq stn (vla-gettextstyle sty acdatarow))) (setq hgt (/ hgt (getvar 'cannoscalevalue))) ) (setq wid (mapcar (function (lambda ( col ) (apply 'max (mapcar (function (lambda ( str ) ( (lambda ( box ) (if box (+ (* 2.5 hgt) (- (caadr box) (caar box))) 0.0)) (textbox (list (cons 01 str) (cons 40 hgt) (cons 07 stn) ) ) ) ) ) col ) ) ) ) (apply 'mapcar (cons 'list lst)) ) ) (if (and ttl (< 0.0 (setq dif (/ (- ( (lambda ( box ) (if box (+ (* 2.5 hgt) (- (caadr box) (caar box))) 0.0)) (textbox (list (cons 01 ttl) (cons 40 hgt) (cons 07 stn) ) ) ) (apply '+ wid) ) (length wid) ) ) ) ) (setq wid (mapcar '(lambda ( x ) (+ x dif)) wid)) ) (setq obj (vla-addtable spc (vlax-3D-point ins) (1+ (length lst)) (length (car lst)) (* 2.0 hgt) (if eqc (apply 'max wid) (/ (apply '+ wid) (float (length (car lst)))) ) ) ) (vla-put-regeneratetablesuppressed obj :vlax-true) (vla-put-stylename obj (getvar 'ctablestyle)) (setq i -1) (if (null eqc) (foreach col wid (vla-setcolumnwidth obj (setq i (1+ i)) col) ) ) (if ttl (progn (vla-settext obj 0 0 ttl) (setq i 1) ) (progn (vla-deleterows obj 0 1) (setq i 0) ) ) (foreach row lst (setq j 0) (foreach val row (vla-settext obj i j val) (setq j (1+ j)) ) (setq i (1+ i)) ) (vla-put-regeneratetablesuppressed obj :vlax-false) obj ) ;; Annotative-p ;; Returns T if the given Textstyle is annotative (defun LM:annotative-p ( sty ) (and (setq sty (tblobjname "style" sty)) (setq sty (cadr (assoc -3 (entget sty '("AcadAnnotative"))))) (= 1 (cdr (assoc 1070 (reverse sty)))) ) ) ;; String to List ;; Separates a string using a given delimiter ;; str - [str] string to process ;; del - [str] delimiter by which to separate the string (defun LM:str->lst ( str del / pos ) (if (setq pos (vl-string-search del str)) (cons (substr str 1 pos) (LM:str->lst (substr str (+ pos 1 (strlen del))) del)) (list str) ) ) (vl-load-com) (princ) ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; ;;----------------------=={ Text File to Table }==----------------------;; ;; ;; ;; Prompts the user to select a text file and generates an AutoCAD ;; ;; Table at the point specified, representing the file data. ;; ;;----------------------------------------------------------------------;; ;; Author: Lee Mac, Copyright © 2013 - [url]www.lee-mac.com[/url] ;; ;;----------------------------------------------------------------------;; (defun c:txt2tab2 ( / *error* del des hdl ins lin lst txt ) (setq ttl nil ;; Table Title (nil for no title) hdl '("A/A" "X" "Y") ;; Table Headings del "," ;; Data Delimiter String ) (defun *error* ( msg ) (if (= 'file (type des)) (close des)) (if (not (wcmatch (strcase msg t) "*break,*cancel*,*exit*")) (princ (strcat "\nError: " msg)) ) (princ) ) (if (setq txt (getfiled "Επιλέξτε το αρχείο P,X,Y (*.txt)" "" "txt" 16)) (if (setq des (open txt "r")) (progn (while (setq lin (read-line des)) (setq lst (cons (mapcar '(lambda ( a b ) a) (LM:str->lst lin del) hdl) lst)) ) (setq des (close des)) (if lst (if (setq ins (getpoint "\nSpecify point for table: ")) (LM:addtable (vlax-get-property (vla-get-activedocument (vlax-get-acad-object)) (if (= 1 (getvar 'cvport)) 'paperspace 'modelspace ) ) (trans ins 1 0) ttl (cons hdl (reverse lst)) nil ) ) (princ "\nNo valid data found in selected file.") ) ) (princ "\nUnable to open selected file for reading.") ) ) (princ) ) ;;---------------------------=={ Add Table }==--------------------------;; ;; ;; ;; Creates an AutoCAD Table Object at the specified point, populated ;; ;; with the given data and optional title. ;; ;;----------------------------------------------------------------------;; ;; Author: Lee Mac, Copyright © 2013 - [url]www.lee-mac.com[/url] ;; ;;----------------------------------------------------------------------;; ;; Arguments: ;; ;; spc - VLA Block object ;; ;; ins - WCS Insertion point for table ;; ;; ttl - [Optional] Table title ;; ;; lst - Matrix list of data to populate the table ;; ;; eqc - If T, columns are of equal width ;; ;;----------------------------------------------------------------------;; ;; Returns: VLA Table Object ;; ;;----------------------------------------------------------------------;; (defun LM:AddTable ( spc ins ttl lst eqc / dif hgt i j obj stn sty wid ) (setq sty (vlax-ename->vla-object (cdr (assoc -1 (dictsearch (cdr (assoc -1 (dictsearch (namedobjdict) "acad_tablestyle") ) ) (getvar 'ctablestyle) ) ) ) ) ) (setq hgt (vla-gettextheight sty acdatarow)) (if (LM:Annotative-p (setq stn (vla-gettextstyle sty acdatarow))) (setq hgt (/ hgt (getvar 'cannoscalevalue))) ) (setq wid (mapcar (function (lambda ( col ) (apply 'max (mapcar (function (lambda ( str ) ( (lambda ( box ) (if box (+ (* 2.5 hgt) (- (caadr box) (caar box))) 0.0)) (textbox (list (cons 01 str) (cons 40 hgt) (cons 07 stn) ) ) ) ) ) col ) ) ) ) (apply 'mapcar (cons 'list lst)) ) ) (if (and ttl (< 0.0 (setq dif (/ (- ( (lambda ( box ) (if box (+ (* 2.5 hgt) (- (caadr box) (caar box))) 0.0)) (textbox (list (cons 01 ttl) (cons 40 hgt) (cons 07 stn) ) ) ) (apply '+ wid) ) (length wid) ) ) ) ) (setq wid (mapcar '(lambda ( x ) (+ x dif)) wid)) ) (setq obj (vla-addtable spc (vlax-3D-point ins) (1+ (length lst)) (length (car lst)) (* 2.0 hgt) (if eqc (apply 'max wid) (/ (apply '+ wid) (float (length (car lst)))) ) ) ) (vla-put-regeneratetablesuppressed obj :vlax-true) (vla-put-stylename obj (getvar 'ctablestyle)) (setq i -1) (if (null eqc) (foreach col wid (vla-setcolumnwidth obj (setq i (1+ i)) col) ) ) (if ttl (progn (vla-settext obj 0 0 ttl) (setq i 1) ) (progn (vla-deleterows obj 0 1) (setq i 0) ) ) (foreach row lst (setq j 0) (foreach val row (vla-settext obj i j val) (setq j (1+ j)) ) (setq i (1+ i)) ) (vla-put-regeneratetablesuppressed obj :vlax-false) obj ) ;; Returns T if the given Textstyle is annotative (defun LM:annotative-p ( sty ) (and (setq sty (tblobjname "style" sty)) (setq sty (cadr (assoc -3 (entget sty '("AcadAnnotative"))))) (= 1 (cdr (assoc 1070 (reverse sty)))) ) ) ;; String to List ;; Separates a string using a given delimiter ;; str - [str] string to process ;; del - [str] delimiter by which to separate the string (defun LM:str->lst ( str del / pos ) (if (setq pos (vl-string-search del str)) (cons (substr str 1 pos) (LM:str->lst (substr str (+ pos 1 (strlen del))) del)) (list str) ) ) ;;----------------------------------------------------------------------;; (vl-load-com) (princ (strcat "\n:: Text2Table.lsp | Version 1.1 | \\U+00A9 Lee Mac " (menucmd "m=$(edtime,0,yyyy)") "\n:: Type \"txt2tab\" to Invoke ::" ) ) (princ) ;;----------------------------------------------------------------------;; ;; End of File ;; ;;----------------------------------------------------------------------;; Edited November 13, 2013 by prodromosm Quote Link to comment Share on other sites More sharing options...
MSasu Posted November 13, 2013 Share Posted November 13, 2013 Just adjust the prefered text height in TABLESTYLE command. Quote Link to comment Share on other sites More sharing options...
Guest Posted November 13, 2013 Share Posted November 13, 2013 can you give me an example to try ? Quote Link to comment Share on other sites More sharing options...
MSasu Posted November 13, 2013 Share Posted November 13, 2013 What I was suggesting you was to call the aforementioned command and adjust there the prefered text height; next call Lee Mac's tool to insert the table. Quote Link to comment Share on other sites More sharing options...
