nic6911 Posted September 17, 2013 Share Posted September 17, 2013 Hi. I don't know if this is actually a question for the newbee section, but I'll give it a try here. I have a model of a boat from some database. It's build from 3D faces but I would like to make it a 3D solid with a thickness of 3mm. I can convert the faces into a surface, but i can't seem to get any of the two models into a 3D solid. I have tried thicken, convtosolid and a lot of other options without luck. I was wondering if I could make two surfaces, one smaller than the other, place them ontop of eachother and create solid between them? But I can't seem to find any info on this. I know this might be a dumb way to draw this boat, but the idea was that I could just convert the model that already exists rather than starting all over (That would take me a lot of hours). Thanks in advance (The files are approx 30kb to big for upload, so I can't share them) Quote Link to comment Share on other sites More sharing options...
JD Mather Posted September 17, 2013 Share Posted September 17, 2013 If you have a watertight envelope then surfsculpt might work. But my guess is that starting over from scratch would be faster than trying to work with flawed data. Quote Link to comment Share on other sites More sharing options...
mikekmx Posted September 17, 2013 Share Posted September 17, 2013 try and reduce the filesize then post it here....sounds an interesting project 30k isn't much to lose - have you purged and re-saved? some careful exploding may reveal some useful geometry to work with if the existing isn't good. (after you've posted it here) Quote Link to comment Share on other sites More sharing options...
nic6911 Posted September 17, 2013 Author Share Posted September 17, 2013 Here is a link to the surface and 3D face files https://www.dropbox.com/sh/0a8mdt9clcv5vye/qnq8RheZo0 Quote Link to comment Share on other sites More sharing options...
nic6911 Posted September 17, 2013 Author Share Posted September 17, 2013 (edited) I don't have the skills to draw this kind of boat hull, so I just wan't to know if there is a way to do this. Edited September 17, 2013 by nic6911 Quote Link to comment Share on other sites More sharing options...
nic6911 Posted September 17, 2013 Author Share Posted September 17, 2013 So far I have made it into a surface, placed it in a solid block and sliced the block with my surface. This gives me a solid piece, where I can use presspull to make a rectangular hole in the middle. Actually that seems to bee a good solution after all. Quote Link to comment Share on other sites More sharing options...
steven-g Posted September 17, 2013 Share Posted September 17, 2013 I use LT so I can't do anything with your drawing, but if you have managed to get the solid shape can't you use the SHELL command to create the 3mm thick solid that you wanted Quote Link to comment Share on other sites More sharing options...
