Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 26
    Full Member adrath's Avatar
    adrath's Computer Details
    Windows 7 64 bit
    Dell Precision t3500
    Civil
    adrath's Discipline Details
    CADD Designer
    Civil
    Most of what I do is commercial and residential land development, with a little bit of transportation and public works thrown in for good measure. I am also a self-proclaimed wizard of blocks, alchemist of assemblies and sorcerer of styles.
    Civil 3D 2014
    Jun 2013
    Texas
    50
    Default How to make an existing block annotative
    I have a dynamic block that I created with a bunch of visibility, rotate and stretch parameters and actions. When I created said block, I meant to make it annotative but forgot about it during the initial block definition. Is there a way that I can make the block annotative now, or do I have to go back and re make the block all over again?
    If at first you don't succeed......explode EVERYTHING!
    Luminous Being tzframpton's Avatar
    tzframpton's Computer Details
    HP Zbook
    Multi-disciplinary
    tzframpton's Discipline Details
    BIM Specialist
    Multi-disciplinary
    Full Virtual Design and Construction BIM services for the MEP engineering and construction industries.
    Revit 2019
    Mar 2006
    Dallas, TX - USA
    9,135
    Just open it up in Block Editor. Without anything being selected, look at the Properties Palette and under "Annotative" select "Yes", then save and exit out of BEDIT mode.
    Done and done.
    Tannar Z. Frampton ™ | Frampton & Associates, Inc.
    Windows 7 64 bit
    Civil
    CADD Designer
    Civil
    Civil 3D 2014
    Jun 2013
    Texas
    50
    Aha! Many thanks! I knew it had to be something simple like that. I just wasn't seeing it.
    HP Zbook
    Multi-disciplinary
    BIM Specialist
    Multi-disciplinary
    Revit 2019
    Mar 2006
    Dallas, TX - USA
    9,135
    When in doubt, right-click. When in doubt in AutoCAD, Properties Palette. This is kinda my motto as of late.
    Glad to help.
  5. #5
    Super Member
    Ski_Me's Computer Details
    DELL (why oh lord must I suffer)
    Electrical
    Ski_Me's Discipline Details
    Fire Alarm tech
    Electrical
    AutoCAD 2018
    Apr 2012
    Edmond. OK
    643
    Make sure your annotative scale is set to the same scale as your block or your block might not show up or sized incorrectly if it's wrong.
  6. #6
    Senior Member
    AFitchguy07's Computer Details
    Windows 7 Professional x64
    Precision T3500
    Xeon W3530 @ 2.80GHz
    12GB DDR3
    Quadro 2000
    320GB HDD @ 7200
    19" Dell P190S (2x)
    See details...
    AFitchguy07's Discipline Details
    Student
    See details below.
    Boilers & heat exchangers.
    AutoCAD 2012
    Dec 2009
    Texas
    112
    I have a very similar issue. I have attached the block with more blocks nested inside it. I make each block annotative and when i insert block in model space and view it through vp in ps, it doesn't seem to be the appropriate scale whatsoever.
    Can someone enlighten me as to why i'm having this issue and a possible solution?
  7. #7
    Senior Member Sbeth85's Avatar
    Architecture 2014
    Sep 2013
    181
    So I have a separate library of blocks I've created.
    When I do BEdit of a block once it's in my drawing, it seems like it only affects the block locally, right? Like it doesn't affect the master block in the library. Is that correct?
    I ask because basically my master block is just normal text that I then insert as a block. I'm trying to make it annotative, but as opposed to when I do BEdit from within the drawing, when I try to alter the master block itself, an annotative option isn't available to click.
    (I made my text non-annotative so that once inserted the block could rescale).
  8. #8
    Forum Deity
    nestly's Computer Details
    Windows 7 Pro (64bit)
    AutoCAD 2015
    Sep 2010
    PA
    3,444
    Inserted blocks are defined locally in the drawing once inserted and they have no association with the "master" block. The only thing they have in common is the block name which can be used to redefine blocks manually, but there's no automatic process. If you need that type of functionality, perhaps look into external references (xref)
  9. #9
    Architecture 2014
    Sep 2013
    181
    nestly- thank you.
    So, how do I make one of my "master" blocks annotative if it's not really a block in and of itself (it's just a normal DWG file)?
  10. #10
    Full Member
    jarr3tt88's Computer Details
    8GB
    NVIDIA Quadro K600
    Architectural
    jarr3tt88's Discipline Details
    Draftsman
    Architectural
    New high end residential, townhouses, and commercial buildings
    AutoCAD LT 2014
    Nov 2013
    Long Island
    86
    The drawing isn't annotative, if you want to keep it in a separate file, I would suggest just making it a block in there and making it annotative.
  1. Annotative Block nested in none Annotative Dynamic Block
    By tuannmvncc in forum AutoCAD General
    Last Post: 12th Jul 2012, 09:41 am
  2. make a block annotative
    By cadmench in forum AutoCAD General
    Last Post: 12th Jan 2012, 08:44 pm
  3. Can you nest a Annotative/dynamic block inside a non-annotative block
    By Sparky in forum AutoCAD Drawing Management & Output
    Last Post: 23rd Sep 2011, 02:25 pm
  4. Not Allowed to Make Block Annotative
    By qball in forum AutoCAD Drawing Management & Output
    Last Post: 21st Jul 2011, 06:23 pm
  5. Insert annotative block as non annotative dwg + trim object scalelist
    By Fnuik in forum AutoLISP, Visual LISP & DCL
    Last Post: 6th Dec 2010, 09:14 pm
