Results 1 to 6 of 6
    Junior Member
    Civil 3D 2011
    Sep 2013
    21
    Default AutoCAD freezes up when Regenerating the MODEL
    Hello Everyone.
    I'm drawing polylines within a chart of elevation contour lines of a mountainous region in my country.
    This is for the design of the drainage hydraulics of highways.
    The Contour Chart which is in jpg format, I have saved it in photoshop in medium size to help make my autocad drawing the less heavier in size.
    In fact, my AutoCAD dwg file is only 69 KB big. I have however georeferenced my Chart by UTM coordinates, so it is a little bit big in the drawing.
    My drawing is in milimetres and the chart size is: 3861 x 2848.
    Here is the layout view of my drawing:
    What is making my AutoCAD crash all the time when I regenerate the model?
    Is there anything I can do to stop this from happening?
    I try to save my drawing all the time though, and whenever my AutoCAD crashes I have to close it up, then I have to open AutoCAD and the drawing again; but this is a bit tedious.
    Senior Member mikekmx's Avatar
    Electrical 2008
    Dec 2012
    UK
    445
    make a copy of your dwg , remove the jpg from the copy, then regen....does it crash?
    try multiple purges and audits to clean up the dwg.
    have you tried working on another computer?
    my acad used to crash all the time (only autocad).....in my case it turns out a memory card was playing up, but you need to narrow the problem down to hardware, software or file
    in my experience, autocad can be awkward with some pics.
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,721
    Try moving your drawing closer to the 0,0 coordinates, do everything you need to do then move it back to the original coordinates.
    Super Member Murph_map's Avatar
    Murph_map's Computer Details
    Win 7, Win 8
    HP something or other and the laptop is an HP too
    2 gigs or 6 gigs in Laptop
    Utilities
    Murph_map's Discipline Details
    Boats and campers renting and repairs
    Utilities
    GIS and Map making.
    Map 3D 2016
    Feb 2011
    TN or KY depends if I'm at work or home.
    924
    As long as you are using Civil3D take advance of the mapping tools there. Try using data connect to bring in the image or mapiinsert command (yes 2 I's). May also want to look at the image cache settings by using the Mapoptions command and reset the cache and temp folder used for images inserted.
    Murph
    Need a boat or camper for the weekend?
  5. #5
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    11,954
    Quote Originally Posted by Murph_map View Post
    That was similar to what I had intended to ask. Why are you doing this in AutoCAD when you have Civil3D?
    What are your computer, OS and graphics card specs?
  6. #6
    Junior Member
    Civil 3D 2011
    Sep 2013
    21
    Quote Originally Posted by SLW210 View Post
    I'm not so good in Civil3D. My company bought it for me though because it was a good offer and there wasn't such a high difference in price in between buying AutoCAD alone or buying AutoCAD plus Civil3D.
    I've been trying to learn Civil3D with a book called "Introducing AutoCAD Civil3D" by the authors: James Wedding and Dana Probert. However, I only started studying that book a few months ago and I had to stop doing the excercises because of other duties I have presently.
    So, since I'm going to the local University I just don't have time currently to learn Civil3D.
    My computer is a "Dell Precision PWS690 Intel(R) Xeon(R) CPU 5130 @2.00GHz"
    Don't know my graphics card specs.
    I have "Windows XP 2002 Professional, Service Pack 3" I didn't upgrade my windows because some specialized Coastal and Civil Engineering softwares I use are not compatible with other more advanced windows versions.
    For now, I only use AutoCAD which I learned very well back in 2002.
  1. AutoCAD 2012 Civ3D lags, will not switch from layout to model, ultimately freezes
    By hanneh in forum AutoCAD Bugs, Error Messages & Quirks
    Last Post: 12th Oct 2011, 04:28 pm
  2. Regenerating model
    By slice_max in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 9th Dec 2010, 08:02 pm
  3. Regenerating model
    Last Post: 24th Nov 2010, 08:50 am
  4. Problem Autocad 2008 - 100% CPU when regenerating
    By mmiket in forum AutoCAD General
    Last Post: 24th Feb 2010, 11:44 pm
  5. AutoCad LT Freezes...
    By chee_dee in forum AutoCAD Drawing Management & Output
    Last Post: 18th Oct 2007, 06:22 am
Tags for this Thread
