hosyn Posted September 22, 2013 Share Posted September 22, 2013 How do i can explode all blocks in drawing with lisp file?? Quote Link to comment Share on other sites More sharing options...
GP_ Posted September 22, 2013 Share Posted September 22, 2013 Try. (defun c:TesT ( / qaf a) (setq qaf (getvar 'qaflags)) (setvar 'qaflags 1) (setq a (ssget "_X" '((0 . "INSERT")))) (command "_explode" a "") (setvar 'qaflags qaf) (princ) ) See also here: http://www.cadtutor.net/forum/showthread.php?77625-explode-all-blocks Quote Link to comment Share on other sites More sharing options...
Tharwat Posted September 22, 2013 Share Posted September 22, 2013 GP , you may need to exclude the Xref blocks from the selection set and besides that if you add the if function to guarantee that the variable a is not equal to nil at last it would be great Quote Link to comment Share on other sites More sharing options...
