Missing text
reyems
When I open my drawing all the text and dimensioning is missing. The fonts are all in the correct folder and when my colleague, in a different city, opens the file (from the same sever) everything shows up on his drawing.
Is there a value setting that I have to change? Really appreciate any help you can provide!
  • Replies 28
  • reyems
    13
  • Dadgad
    5
  • Tyke
    4
  • Tuns
    4
Popular Days
Posted Images
I've tried both model and paper. This is a file from an architect. When I look at the Text Style menu none of their styles has a check in the annotative box.
What is your ANNOALLVISIBLE system variable set to?
Could it be that your drawing area colour is the same as the text? On a copy of your drawing use QSELECT to select all the text objects in the drawing and try setting their colour to a contrast to your graphics window background colour. Your colleague could just have a different colour to you.
The OP said
...none of their styles has a check in the annotative box
so the ANNOALLVISIBLE sysvar would have no effect.
The OP said so the ANNOALLVISIBLE sysvar would have no effect.
I believe the TEXT STYLES were described as non-annotative?
There was no mention of Dimension styles.
I am inclined to suspect that, as you opined the text color may be the culprit, and that perhaps it should be set to 7. :)
It's actually a problem with every drawing in this folder. There are about 130 drawing files and 5 text fonts. Text will not appear in any of these drawings (however, as I mentioned earlier, it works for my colleague). Any other drawing I open, from other jobs, or from the same architect - they all work fine for me.
yes, this has been a problem for months. I thought the file was corrupt. It was only this morning that I realized someone else was able to see the text and dimensions.
