reyems Posted September 23, 2013 Share Posted September 23, 2013 When I open my drawing all the text and dimensioning is missing. The fonts are all in the correct folder and when my colleague, in a different city, opens the file (from the same sever) everything shows up on his drawing. Is there a value setting that I have to change? Really appreciate any help you can provide! Quote Link to comment Share on other sites More sharing options...
Tuns Posted September 23, 2013 Share Posted September 23, 2013 Did you check if the layer for the text was frozen on your AutoCAD? Maybe the TEXTTOFRONT command will work? Quote Link to comment Share on other sites More sharing options...
reyems Posted September 23, 2013 Author Share Posted September 23, 2013 I tried the TEXTTOFRONT - it said it moved 535 objects - but I don't see any change. I have all layers on and not frozen. ARGHHHH! Any other thoughts? Quote Link to comment Share on other sites More sharing options...
ReMark Posted September 23, 2013 Share Posted September 23, 2013 Are you in model space or a paper space layout? Are you using annotative text? Quote Link to comment Share on other sites More sharing options...
reyems Posted September 23, 2013 Author Share Posted September 23, 2013 I've tried both model and paper. This is a file from an architect. When I look at the Text Style menu none of their styles has a check in the annotative box. Quote Link to comment Share on other sites More sharing options...
Dadgad Posted September 23, 2013 Share Posted September 23, 2013 I've tried both model and paper. This is a file from an architect. When I look at the Text Style menu none of their styles has a check in the annotative box. What is your ANNOALLVISIBLE system variable set to? Quote Link to comment Share on other sites More sharing options...
Tyke Posted September 23, 2013 Share Posted September 23, 2013 Could it be that your drawing area colour is the same as the text? On a copy of your drawing use QSELECT to select all the text objects in the drawing and try setting their colour to a contrast to your graphics window background colour. Your colleague could just have a different colour to you. Quote Link to comment Share on other sites More sharing options...
reyems Posted September 23, 2013 Author Share Posted September 23, 2013 It is set to 1. Quote Link to comment Share on other sites More sharing options...
Tyke Posted September 23, 2013 Share Posted September 23, 2013 What is your ANNOALLVISIBLE system variable set to? The OP said ...none of their styles has a check in the annotative box so the ANNOALLVISIBLE sysvar would have no effect. Quote Link to comment Share on other sites More sharing options...
reyems Posted September 23, 2013 Author Share Posted September 23, 2013 I tried qselect - chose text in entire drawing (tried text and mtext). O items selected comes up. Quote Link to comment Share on other sites More sharing options...
Tuns Posted September 23, 2013 Share Posted September 23, 2013 Is this only a problem in that one drawing or is it every drawing you open? Quote Link to comment Share on other sites More sharing options...
Dadgad Posted September 23, 2013 Share Posted September 23, 2013 The OP said so the ANNOALLVISIBLE sysvar would have no effect. I believe the TEXT STYLES were described as non-annotative? There was no mention of Dimension styles. I am inclined to suspect that, as you opined the text color may be the culprit, and that perhaps it should be set to 7. Quote Link to comment Share on other sites More sharing options...
reyems Posted September 23, 2013 Author Share Posted September 23, 2013 It's actually a problem with every drawing in this folder. There are about 130 drawing files and 5 text fonts. Text will not appear in any of these drawings (however, as I mentioned earlier, it works for my colleague). Any other drawing I open, from other jobs, or from the same architect - they all work fine for me. Quote Link to comment Share on other sites More sharing options...
reyems Posted September 23, 2013 Author Share Posted September 23, 2013 Dimension styles are not annotative. Quote Link to comment Share on other sites More sharing options...
Tuns Posted September 23, 2013 Share Posted September 23, 2013 Have you tried restarting AutoCAD and your computer? I really can't think of what the problem could possibly be. Quote Link to comment Share on other sites More sharing options...
reyems Posted September 23, 2013 Author Share Posted September 23, 2013 yes, this has been a problem for months. I thought the file was corrupt. It was only this morning that I realized someone else was able to see the text and dimensions. Quote Link to comment Share on other sites More sharing options...
SLW210 Posted September 23, 2013 Share Posted September 23, 2013 Were these drawings created with something other than Vanilla AutoCAD? Quote Link to comment Share on other sites More sharing options...
reyems Posted September 23, 2013 Author Share Posted September 23, 2013 The drawings were created in AutoCAD but I do not know which version. I only know that my colleague and I both use AutoCAD 2012 and he can see text and dims. Quote Link to comment Share on other sites More sharing options...
Tyke Posted September 23, 2013 Share Posted September 23, 2013 There was no mention of Dimension styles. Sorry, point taken. Perhaps the OP could upload a small drawing for us to look at? Quote Link to comment Share on other sites More sharing options...
Tuns Posted September 23, 2013 Share Posted September 23, 2013 And this is... the Twilight Zone. Quote Link to comment Share on other sites More sharing options...
