Results 1 to 5 of 5
    Senior Member sandiegophil's Avatar
    sandiegophil's Computer Details
    Windows 10 64bit
    HP z640
    E5-2609 v4 1.7GHz
    64gb
    nvidia m3000
    ssd
    2-Z27s
    Civil
    sandiegophil's Discipline Details
    CAD Manager - County of San Diego DPW
    Civil
    Civil 3D 2018
    Feb 2009
    San Diego, CA
    274
    Default Problem applying render materials to pipes
    Hello,
    I have a large pipe network. All works well with one exception. I am trying to apply a render material to the pipes and it renders very poorly. I drew a cube and sphere next to the network at an appropriate size, applied the same material and the cube and sphere render great but the pipes are nasty. I tried adjusting my ucs to one of the pipes and reapplying the material but I get the same result. Then I drew a cylinder in plan view the same size and length as a pipe and it worked great too. What am I missing? All suggestions are greatly appreciated.
    Thanks,
    Phil
    Senior Member Emigrato's Avatar
    See details...
    Emigrato's Discipline Details
    See details below.
    Cisco CCNA
    Map 3D 2006
    Sep 2011
    165
    Seems like that pipe is not a unique polyface mesh, so the render applies to each single 3Dface, sir.
    Windows 10 64bit
    HP z640
    E5-2609 v4 1.7GHz
    64gb
    nvidia m3000
    ssd
    2-Z27s
    Civil
    Civil
    Civil 3D 2018
    Feb 2009
    San Diego, CA
    274
    If anyone is interested I have a ticket open with Autodesk regarding this issue. They tried everything I did and their 'solution' was to explode all pipes and structures, then apply materials. This is now a confirmed bug in 2012, 2013 and 2014. Although their solution works I do not think it is an appropriate one.
    Regards,
    Phil
    Senior Member lrm's Avatar
    lrm's Computer Details
    Windows 7 64-bit
    16 GB
    Education
    lrm's Discipline Details
    Teacher, AEC and mechanical
    Education
    Civil and Mechanical
    3ds Max 2017
    Jan 2010
    Massachusetts, USA
    380
    Try applying the material in a plan view (where you said it looks good) and then convert the pipe to a block. Orient the block so that the pipe is in the correct position. I have used this technique in the past. Controlling material mapping in AutoCAD has become very difficult in recent versions. ~ Lee M.
  5. #5
    Windows 10 64bit
    HP z640
    E5-2609 v4 1.7GHz
    64gb
    nvidia m3000
    ssd
    2-Z27s
    Civil
    Civil
    Civil 3D 2018
    Feb 2009
    San Diego, CA
    274
    Lee,
    I will certainly give that a try. The pipes and structures look lousy in plan and model views. The manually created cylinders and boxes look great in both when rendered. Also, my model has over 300 pipes and ~90 structures. Thanks for your reply, much appreciated,
    Regards,
    Phil
  1. Applying Materials to Single Face
    By jbctln in forum AutoCAD 3D Modelling & Rendering
    Last Post: 22nd Jun 2012, 12:47 pm
  2. Applying materials
    By roof11 in forum AutoCAD 3D Modelling & Rendering
    Last Post: 23rd Jul 2010, 02:15 pm
  3. Render Tab for Materials
    By numberOCD in forum MEP
    Last Post: 22nd Jul 2010, 03:25 pm
  4. applying materials
    By bjenk8100 in forum AutoCAD 3D Modelling & Rendering
    Last Post: 23rd Feb 2010, 09:27 pm
  5. Applying materials to walls
    By _E_ in forum AutoCAD 3D Modelling & Rendering
    Last Post: 27th Sep 2009, 02:47 am
Tags for this Thread
