Page 1 of 2 1 2 LastLast
Results 1 to 10 of 11
    Junior Member
    AutoCAD 2010
    Jul 2010
    Northants UK
    21
    Default CTAB Field editing
    Evening All
    I have a scenario where I want to use some thing like the system variable CTAB in a field but have it report another Layout Name in the drawing rather than the Layout that I'm working in. Let me explain.....
    I'm producing phasing drawings for a well known supermarket and I use the Layout Tab name to drive the phasing dates within the Layout. ie P1 - Thu 23 Oct. I then use this to populate the title block etc with the system variable CTAB this saves me a whole load of time as I know the dates on the Layout tab name are correct and will therefore be right in the drawings (upwards of 25 drawings per project).
    I've just had a request to add some more information into the drawings but this has the date for the next phase ie P2 - Fri 24 Oct, I cant use the CTAB variable as it will report the wrong date ; Is there a way I can report another Layout Tab name with a system variable or through Diesel?
    Hope that makes sense!
    Stenna
    Forum Deity steven-g's Avatar
    steven-g's Computer Details
    Win 7
    Construction
    steven-g's Discipline Details
    Draughtsman
    Construction
    I work in the estimating department of a large building contractor.
    AutoCAD 2018
    May 2013
    An Englishman in Belgium
    2,165
    AFAIK there is no way to read another tab as CTAB stands for current tab, you could possibly look at using environmental variables or creating list of the phase dates in model space and either linking to them with fields or even using viewports within your title block to 'look' at those values.
    Luminous Being tzframpton's Avatar
    tzframpton's Computer Details
    HP Zbook
    Multi-disciplinary
    tzframpton's Discipline Details
    BIM Specialist
    Multi-disciplinary
    Full Virtual Design and Construction BIM services for the MEP engineering and construction industries.
    Revit 2019
    Mar 2006
    Dallas, TX - USA
    9,140
    I'll back Steven up on that one. CTAB = Current Tab and is read only.
    Tannar Z. Frampton ™ | Frampton & Associates, Inc.
    Junior Member
    AutoCAD 2010
    Jul 2010
    Northants UK
    21
    Morning
    Thanks for the replies I'm not saying I want to use CTAB specifically I was wondering if there is a command, system variable or some diesel that would allow me to report another Layout Tabs entry
    Stenna
  5. #5
    Win 7
    Construction
    Draughtsman
    Construction
    AutoCAD 2018
    May 2013
    2,165
    Quote Originally Posted by stenna View Post
    Morning
    Stenna
    Unfortunately that is the only variable, relating to tabs and is not available outside the current tab, thats why I suggested maybe using a different approach. Unless some clever soul knows a way using LISP
  6. #6
    HP Zbook
    Multi-disciplinary
    BIM Specialist
    Multi-disciplinary
    Revit 2019
    Mar 2006
    Dallas, TX - USA
    9,140
    Yeah, LISP or .NET or any of the equivalent programming languages would be needed I assume. One of the guru's might post something, or maybe try posting in the LISP forum here to see if someone's already created a program that has what you need.
  7. #7
    Super Member Tuns's Avatar
    Tuns's Computer Details
    Windows 7 (64-bit)
    Intel Core I3-2120
    4.0 GB
    AutoCAD LT 2014
    Jun 2013
    San Antonio, Texas
    784
    Quote Originally Posted by tzframpton View Post
    CTAB isn't read only. I'm just telling you in case you ever want to use it, not to one up you or anything. The OP can probably make an xref or something to make this work. I don't like using them but I don't know how else you'd link two drawings together.
    Never argue with an idiot. He will drag you down to his level and beat you with experience.
  8. #8
    HP Zbook
    Multi-disciplinary
    BIM Specialist
    Multi-disciplinary
    Revit 2019
    Mar 2006
    Dallas, TX - USA
    9,140
    I've been using CTAB since AutoCAD 2007.... I always thought it was a read only variable? Since it simply "displays" the Current Tab name? And I know you're not trying to one up me. All good brutha!
  9. #9
    Windows 7 (64-bit)
    Intel Core I3-2120
    4.0 GB
    AutoCAD LT 2014
    Jun 2013
    San Antonio, Texas
    784
    Attachment 44129 Check that out. It was posted by Tyke in another thread but it's fairly handy for the every day AutoCAD user. It displays the current layout tab that your using and you can change which layout your on by typing in the layout name.
  10. #10
    Forum Deity rkent's Avatar
    rkent's Computer Details
    WIN7 PRO 64bit
    Dell OptiPlex 7020
    i7 4790 3.6GHz
    16GB, 1600MHz, DDR3 non-ECC 2x8GB
    AMD Radeon 2GB
    Samsung 480Gb SSD
    Dell 24" FS (2x)
    Mechanical
    rkent's Discipline Details
    Mechanical
    Mechanical 2017
    Nov 2007
    4,598
    stenna - you could use custom fields, defined in the drawing properties. Better yet start using the SSM and you can handle it there.
    Sometimes there's a man... I won't say a hero, 'cause, what's a hero? But sometimes, there's a man. And I'm talkin' about the Dude here. Sometimes, there's a man, well, he's the man for his time and place. He fits right in there. And that's the Dude, in Los Angeles. - The Stranger, The Big Lebowski
  1. Lisp routine use csv to update title block attributes - on ctab
    By HRae in forum AutoLISP, Visual LISP & DCL
    Last Post: 16th Feb 2014, 12:06 am
  2. Field Edit or Field Input Automation
    By KAPC in forum AutoLISP, Visual LISP & DCL
    Last Post: 11th Jun 2013, 01:04 pm
  3. CTAB in Field
    By SLW210 in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 2nd Mar 2012, 04:57 pm
  4. EATTEXT and CTAB attribute
    By indianateresa in forum AutoCAD Drawing Management & Output
    Last Post: 18th Dec 2008, 11:36 pm
  5. Field text editing
    By Nippon in forum AutoCAD Drawing Management & Output
    Last Post: 31st Jul 2006, 09:18 am
Tags for this Thread
