Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 22
    Senior Member
    Manufacture
    iainlines's Discipline Details
    Manufacture
    I make boxes n stuff!
    AutoCAD 2013
    Dec 2011
    Smack bang in the middle of England
    264
    Default Bending a 2D object
    Hi all,
    Is there any way I can bend a 2D object? I have a drawing of a hydraulic hose running straight in the x axis. What I want to do is to be able is to bend the hose around 90 degress (to fit in a case) without altering the overall length & width. Poor explanation but hopefully someone will be able to give me an answer
    I have attached a simple drawing that should explain the problem. I know the lengths don't match, this is purely for illustration
    Thanks
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,851
    Sounds like a job more suited for Inventor (i.e. - Tube and Pipe package of Inventor Professional).
    Do you know what the minimum bend radius is for the hydraulic hose you have selected?
    Senior Member
    Manufacture
    Manufacture
    AutoCAD 2013
    Dec 2011
    264
    I should probably clarify.....I'm not actually drawing the hose itself, just the packaging (cnc machined foam) that it will go in. I would like to get it around 100mm radius. I have files of the shapes layed flat but I need to get them within the confines of the packaging ideally without a lot of re drawing as time is against me
    Cheers for the quick reply, as ever
    AutoCAD 2013
    Nov 2011
    6,045
    Quote Originally Posted by iainlines View Post
    Hi all,
    Thanks
    ReMark is correct, Inventor could do it easily, but you can fake it, if all you need is a graphic representation in Autocad.
  5. #5
    Senior Member
    Manufacture
    Manufacture
    AutoCAD 2013
    Dec 2011
    264
    Thanks Dadgad, but I don't think I'm being very clear. The lengths DO need to match....they just didn't in the quick sketch I knocked up. I want to take a rectangle and bend it without altering the length or width. Possible?
  6. #6
    AutoCAD 2013
    Nov 2011
    6,045
    Thanks Dadgad, but I don't think I'm being very clear. The lengths DO need to match....they just didn't in the quick sketch I knocked up. I want to take a ractangle and bend it without altering the length of width. Possible?
    I scaled and offset from the centerline of your sample hose, so that the length of the centerline of the new hose, and the OD are the same as the straight sample. Perhaps you want to use parametric constraints to constrain the bent x or y lengths too?
  7. #7
    Senior Member
    Manufacture
    Manufacture
    AutoCAD 2013
    Dec 2011
    264
    What I would like in an ideal world would be to draw what I need to straight acorss the X the bend it to produce something like the attached
  8. #8
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,851
    Keep dreaming.
    Why is it necessary to foam pack hydraulic hose? Can't it just be "blocked"?
  9. #9
    Senior Member
    Manufacture
    Manufacture
    AutoCAD 2013
    Dec 2011
    264
    Bah! Didn't think so. Oh well
    These are hoses for a helicopter. The are placed within the foam then a Pelican case for transport and storage. Customer requirements
  10. #10
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,851
    So the hoses are that delicate? And they are being used on helicopters? Remind me not to ride in one of them.
  1. Bending Tubes?
    By crevio in forum 3D Modelling
    Last Post: 21st Nov 2009, 04:24 pm
  2. Bending Text
    By Nick@TE-Direct in forum AutoCAD 3D Modelling & Rendering
    Last Post: 9th Jun 2009, 02:56 pm
  3. Tube Bending
    By indigoxtreme02 in forum Autodesk Inventor
    Last Post: 19th Apr 2009, 01:19 pm
  4. -bending???
    By TheNewGuy in forum AutoCAD 3D Modelling & Rendering
    Last Post: 15th Apr 2009, 02:23 am
  5. Bending objects
    By Haz in forum 3D Modelling
    Last Post: 17th Feb 2009, 04:14 pm
