+ Reply to Thread
Results 1 to 8 of 8
  1. #1
    Full Member abraxus's Avatar
    Using
    AutoCAD 2012
    Join Date
    Aug 2013
    Posts
    68
    Default Bounding Box for Selection Set
    What would be the best way to get a bounding box for a selection set in VBA?
    Google found a LISP routine that can do it, but it has been years since I have used LISP
    I was thinking someone here might be easily able to convert this small LISP routine to VBA for me
    Code:
    (defun LM:SSBoundingBox ( ss / i l1 l2 ll ur )
        (vla-getboundingbox (vlax-ename->vla-object (ssname ss (setq i (1- i)))) 'll 'ur)
        (setq
          l1 (cons (vlax-safearray->list ll) l1)
          l2 (cons (vlax-safearray->list ur) l2)
       (mapcar '(lambda ( a b ) (apply 'mapcar (cons a b))) '(min max) (list l1 l2))
  2. #2
    Using
    AutoCAD 2012
    Join Date
    Aug 2013
    Posts
    68
    Default
    i guess now that i think about it - it's probably not all that hard to just iterate thru each item in the selection set and track the min and max x and y coords... i guess i was just thinking that autocad would have this built in... guess not
  3. #3
    Using
    AutoCAD 2012
    Join Date
    Aug 2013
    Posts
    68
    Default
    ok, so yeah, i feel like an idiot for even asking this question now
    here's the solution for those of you who wondered
    Code:
    Public Sub GetSSBoundingBox(ss As AcadSelectionSet, ptMin As Variant, ptMax As Variant)
      Dim entItem As AcadEntity
      Dim ptImin As Variant
      Dim ptImax As Variant
      Const X = 0
      Const Y = 1
      ss(0).GetBoundingBox ptMin, ptMax
      For Each entItem In ss
        entItem.GetBoundingBox ptImin, ptImax
        If ptImin(X) < ptMin(X) Then ptMin(X) = ptImin(X)
        If ptImin(Y) < ptMin(Y) Then ptMin(Y) = ptImin(Y)
        If ptImax(X) > ptMax(X) Then ptMax(X) = ptImax(X)
        If ptImax(Y) > ptMax(Y) Then ptMax(Y) = ptImax(Y)
      Next
    End Sub
    and here is how to call the function
    Code:
    Public Sub FlipTest()
      Dim ssFlip As AcadSelectionSet
      Dim pt1 As Variant
      Dim pt2 As Variant
      ' get selection set from user
      Set ssFlip = ThisDrawing.SelectionSets.Add("flip")
      ssFlip.SelectOnScreen
      ' get bounding box of selection set
      GetSSBoundingBox ssFlip, pt1, pt2
      ' draw a line from point to point
      ThisDrawing.ModelSpace.AddLine pt1, pt2
      ssFlip.Delete
    End Sub
  4. #4
    Forum Newbie
    Discipline
    Electrical
    Using
    AutoCAD 2014
    Join Date
    Aug 2017
    Posts
    5
    Smile plotting issue
    your code is awesome
    is there any way to pass this pt1 & pt2 to plot (window) for printing
  5. #5
    Quantum Mechanic BIGAL's Avatar
    Using
    Civil 3D 2016
    Join Date
    Dec 2005
    Location
    GEELONG AUSTRALIA
    Posts
    10,706
    Default
    selvamani the code does this look at ptimin ptimax . You can pass these to a plot window sub and say use Fit. There is lots of plot code here mainly lisp but I am sure you can find a VBA version, if thats what you want. https://forums.autodesk.com/t5/autoc...t/td-p/3249378
    abraxus a check for which space your in may be a good idea. Tested in a layout and drew a line in model space. Nice code though can see lots of use like plotting.
  6. #6
    Forum Newbie
    Discipline
    Electrical
    Using
    AutoCAD 2014
    Join Date
    Aug 2017
    Posts
    5
    Default
    thanks BIGAL
    i need to find specific block which is used multiple times in a cad and and change its attributes values one by one through vba
    any help on this please
  7. #7
    Using
    Civil 3D 2016
    Join Date
    Dec 2005
    Location
    GEELONG AUSTRALIA
    Posts
    10,706
    Default
    selvamani do a search here for attribute & vba lots of posted examples.
  8. #8
    Forum Newbie
    Discipline
    Electrical
    Using
    AutoCAD 2014
    Join Date
    Aug 2017
    Posts
    5
    Default setwindow plot issue
    this points iam getting from bounding box in main sub
    i dont know what is happenning i got only empty window as layout but actually points given to setplotwindow is not empty plese help on this code for your reference
    Sub Example_SetWindowToPlot(point1 As Variant, point2 As Variant)
    ' This example allows the user to define an area in the current layout
    ' and displays a plot preview of the defined area.
    ' * Note: You have to exit the
    ' plot preview before the VBA example will stop and control will be returned
    AppActivate ThisDrawing.Application.Caption
    ' Dim point1 As Variant, point2 As Variant
    ' Get first point in window
    'point1 = ThisDrawing.Utility.GetPoint(, "Click the lower-left of the window to plot.")
    ReDim Preserve point1(0 To 1) ' Change this to a 2D array by removing the Z position
    ' Get second point in window
    'point2 = ThisDrawing.Utility.GetPoint(, "Click the upper-right of the window to plot.")
    ReDim Preserve point2(0 To 1) ' Change this to a 2D array by removing the Z position
    ' Send information about window to current layout
    ThisDrawing.ActiveLayout.SetWindowToPlot point1, point2
    ThisDrawing.Plot.DisplayPlotPreview acFullPreview
    ' Read back window information
    ThisDrawing.ActiveLayout.GetWindowToPlot point1, point2
    MsgBox "Press any key to plot the following window:" & vbCrLf & vbCrLf & _
    "Lower Left: " & point1(0) & ", " & point1(1) & vbCrLf & _
    "Upper Right: " & point2(0) & ", " & point2(1)
    ' Be sure to plot a view, not some other plot style
    ThisDrawing.ActiveLayout.PlotType = acWindow
    ' Send Plot To Window
    ThisDrawing.ActiveLayout.ConfigName = "DWG to PDF.pc3"
    End Sub
Similar Threads
  1. Bounding box for all objects?
    By bsamc2000 in forum AutoLISP, Visual LISP & DCL
    Last Post: 7th Feb 2017, 10:40 pm
  2. Bounding Box LISP
    By nicolas in forum AutoLISP, Visual LISP & DCL
    Last Post: 4th Nov 2010, 04:40 pm
  3. MTEXT--width of the bounding box
    By mattcai in forum AutoCAD Beginners' Area
    Last Post: 4th Nov 2009, 06:19 pm
  4. xRef Bounding Box
    By andybone in forum AutoCAD Drawing Management & Output
    Last Post: 6th Apr 2009, 03:50 pm
  5. Removing Bounding Box From Image
    By Keith1211 in forum AutoCAD Beginners' Area
    Last Post: 30th Jan 2006, 09:15 pm
Posting Permissions
  • You may not post replies
  • You may not edit your posts
