Essentially, AutoCAD will not delete layers that have objects on them or are referenced by block references. My guess is that you have a block in the drawing that still references those layers you can't delete. You could purge the block (assuming it's not being used in the drawing) and then purge the layers. Use the PURGE command - you may need to do it a couple of times.
