jcaz15 Posted September 29, 2013 Share Posted September 29, 2013 Hi everyone!!! I know my question should be a easy question for a mid level civil 3d user, but not for me. I need to create a worst defined contour from a surface created via well shaped contours, why I need this, because a need to export a surface without to much detail to a fem program (plaxis). So the question is; How to create new contours from a already created surface_ Hope you can help me. Quote Link to comment Share on other sites More sharing options...
Organic Posted September 29, 2013 Share Posted September 29, 2013 Hi everyone!!! I know my question should be a easy question for a mid level civil 3d user, but not for me. I need to create a worst defined contour from a surface created via well shaped contours, why I need this, because a need to export a surface without to much detail to a fem program (plaxis). So the question is; How to create new contours from a already created surface_ Hope you can help me. What do you mean by "worst defined contour"? Quote Link to comment Share on other sites More sharing options...
jcaz15 Posted September 29, 2013 Author Share Posted September 29, 2013 Hope I can explain myself. The contours I have, have a lot of snap points, so when there is a curve it generates a lot of triangles which can define very well a curve section, but this triangles are so irregular in ther lengths (they are not equilateral), but because the application which I am working on, a prefer few triangles but with regular shapes (equilateral lengths) I dont care if they dont reproduce so exactly the curves... this is because in fem analysis thats a good practice. So i was thinking that I could create a surface from the real-originals contours and then from that surface create new contours, but with less points from which triangles will be created.... I was thinking it should be an option which says something like ¨preferred aproximation, or number of snaps¨don´t know, hope you can help me.... Or/and how to export surfaces to a *.3ds format. Gracias por su tiempo dedicado. Quote Link to comment Share on other sites More sharing options...
Murph_map Posted September 29, 2013 Share Posted September 29, 2013 Are you using civil3D or Vanilla AutoCAD and what version? If using C3D look at the Smoothing functions and/or using Civil Views in 3ds Max. Quote Link to comment Share on other sites More sharing options...
Emigrato Posted September 30, 2013 Share Posted September 30, 2013 Señor, instead of simplifing an existing surface, try to weed the original contours (command _MAPCLEAN => "Simplify objects") then recreate the surface. Quote Link to comment Share on other sites More sharing options...
