First of all sorry for my bad english.
I wonder how do I change the default value of the angle that is between in the command UCS
"specify rotation angle about X axis :"
from 180.00 to 90.00
Thanks
Change dwg. UCS
First “UCSFOLLOW” set to “0”
Then “UCS” enter “e” enter select what u want angle direction line
And another change only cursor hair “snapang” enter value ok.
Change dwg. UCS
Thanks for the help but did not work the way I wanted.
I'm working on the SW isometric and the reason I want to change the default value of 180.00 to 90.00 is for all the times I typed the command UCS then enter X I do not need to enter the angle of 90.00. The angle of 90.00 would be the default angle
You're looking for a system variable.
Command: UCSAXISANG
Enter new value for UCSAXISANG :90
Then press the Enter key.
Done.
Command: UCSAXISANG
Done.
Thanks ReMark
That's the command I was looking for.
