97catintenn Posted October 6, 2013 Share Posted October 6, 2013 How do I make my doors and windows look normal? The windows are the default 3'x5' and the doors are a default 3'x7'. Also when looking at the house plan in birds eye view, the windows are not visible. Look below, thanks house2.dwg Quote Link to comment Share on other sites More sharing options...
danellis Posted October 7, 2013 Share Posted October 7, 2013 Are these custom window styles, or the standard ones? dJE Quote Link to comment Share on other sites More sharing options...
Dadgad Posted October 7, 2013 Share Posted October 7, 2013 Are these custom window styles, or the standard ones? dJE I gotta say that at this point in time, they are looking pretty custom! Sorry, the devil made me say that. Might I add, that earlier I did open your drawing hoping I might be able to shed some light, but none was forthcoming. I knew somebody would be better equipped than I to try and resolve your problem, No doubt Dan will be able to get you back on the tracks! Quote Link to comment Share on other sites More sharing options...
f700es Posted October 7, 2013 Share Posted October 7, 2013 Well I think I found your problem... Your door and frame dims are "a bit" off Select your item in a 3D view and then click on "Edit Style" in the panel above. Here you will get this dialog box to make the needed changes to your door and window styles. Quote Link to comment Share on other sites More sharing options...
Dadgad Posted October 7, 2013 Share Posted October 7, 2013 I have just started ordering some nice hardwood windows and frames for the house I am building, great fun. I CONSIDERED using 10 inch thick glass for them, but I also wanted to be able to open them, and since my walls are only 6 inches thick I decided to go with 5mm thick glass instead. Quote Link to comment Share on other sites More sharing options...
Dana W Posted October 7, 2013 Share Posted October 7, 2013 I have just started ordering some nice hardwood windows and frames for the house I am building, great fun.I CONSIDERED using 10 inch thick glass for them, but I also wanted to be able to open them, and since my walls are only 6 inches thick I decided to go with 5mm thick glass instead. My windows are 10" double glazed. They save a lot in HVAC operational costs. It'll only take me 563 years to recover the $3000,000.00 the windows cost me. Quote Link to comment Share on other sites More sharing options...
PotGuy Posted October 7, 2013 Share Posted October 7, 2013 Ooh boy, that's a lot. I'm sure that was a joke that whooshed me. Quote Link to comment Share on other sites More sharing options...
97catintenn Posted October 7, 2013 Author Share Posted October 7, 2013 Your door and frame dims are "a bit" off That's it! For some reason that's what cad is defaulting to. I changed my settings on my drawing and that solved my problem. But then I opened a new drawing, drew a wall and added a window...same problem. 10" glass again! Is it because I'm not starting off with a template? Quote Link to comment Share on other sites More sharing options...
Dana W Posted October 7, 2013 Share Posted October 7, 2013 Ooh boy, that's a lot. I'm sure that was a joke that whooshed me. $298,000.00 for crane rental. Quote Link to comment Share on other sites More sharing options...
Dadgad Posted October 8, 2013 Share Posted October 8, 2013 That's it! For some reason that's what cad is defaulting to. I changed my settings on my drawing and that solved my problem. But then I opened a new drawing, drew a wall and added a window...same problem. 10" glass again! Is it because I'm not starting off with a template? Why do you choose to nut use a standard Architectural template? What is your QNEW (default for new drawing template) set to now, in OPTIONS, on the FILES tab, Template Settings? Quote Link to comment Share on other sites More sharing options...
f700es Posted October 8, 2013 Share Posted October 8, 2013 Is it because I'm not starting off with a template? Well you are starting off with some template, just not a good one. Your default one has some funky settings in it or your default window and door style has been messed with. Start looking there. Quote Link to comment Share on other sites More sharing options...
