Results 1 to 9 of 9
    Full Member Keywordkid's Avatar
    Keywordkid's Computer Details
    Win 7
    Architectural
    Keywordkid's Discipline Details
    CAD Manager
    Architectural
    AutoCAD 2012
    Jun 2012
    London, UK
    86
    Default Temporary pc3 location
    Is it possible to define a path where users can save temporary pc3 files?
    Currently our plot settings are defined in a read only location, this presents problems when users want to make single plot changes to the defaults as the location will not allow the temporary file to be saved.
    Hope you can advise.
    Super Member Tuns's Avatar
    Tuns's Computer Details
    Windows 7 (64-bit)
    Intel Core I3-2120
    4.0 GB
    AutoCAD LT 2014
    Jun 2013
    San Antonio, Texas
    784
    Is getting them to default to a read only location even possible? When I installed AutoCAD it already had a folder for plot styles that isn't read only.
    Never argue with an idiot. He will drag you down to his level and beat you with experience.
    Senior Member
    Mike_Taylor's Computer Details
    Windows 7 64 Bit
    Intel I7 2600
    16GB DDR3
    Nvidia GTX 550
    2TB @ 7500 RPM
    1 TB @ 7500 RPM, 750GB @ 5200 RPM
    2 @ 24"
    Electrical
    Mike_Taylor's Discipline Details
    Rombald Inc. - CAD Designer and CAD Specialist
    Electrical
    Primarily Electrical Building Systems Design The "Lighting Guy"
    AutoCAD 2014
    Jul 2009
    Stratford, Ontario, Canada
    466
    You can change the file location after the install to a new location which can be read only. The only thing I can think of is adding a second location that has write access and moving is to the top of the 2 locations. This should make this the default location when you are prompted to save the PC3 file. The only thing I would be wary of using this method would be that it will pick up the plotter configurations from here as well so the names must be unique or keep the location empty.
    Forum Deity Dana W's Avatar
    Dana W's Computer Details
    Windows 8 64 bit
    Dell XPS ONE 2710
    Dunno
    Intel I-5 3330S @ 2.7 Ghz
    6 Gb
    On board barely adequate
    1 Terrabyte
    1 Terrabyte external
    All in one 27" touch & pen
    Construction
    Dana W's Discipline Details
    Architectural Millwork Designer/Draftsman
    Construction
    Custom commercial millwork.
    AutoCAD LT 2019
    Feb 2010
    Oviedo, Florida
    4,782
    What happens when one of these drawings is opened on another computer and it can't find the plotter config files?
    The S197 gen Ford Mustang, and the F-4 Phantom both prove the same theory. "With enough power applied, a school bus will fly."
  5. #5
    Senior Member
    Windows 7 64 Bit
    Intel I7 2600
    16GB DDR3
    Nvidia GTX 550
    2TB @ 7500 RPM
    2 @ 24"
    Electrical
    Electrical
    AutoCAD 2014
    Jul 2009
    466
    Quote Originally Posted by Dana W View Post
    I was under the assumption it would be in a shared location, although if it is not then my suggestion would not work.
  6. #6
    Windows 8 64 bit
    Dell XPS ONE 2710
    Dunno
    6 Gb
    1 Terrabyte
    Construction
    Construction
    AutoCAD LT 2019
    Feb 2010
    Oviedo, Florida
    4,782
    Quote Originally Posted by Mike_Taylor View Post
    I was just chiming in because I telecommute without a VPN, just email, so I could not make that sort of change myself. I have enough trouble trying to get plotstyles from some of my clients if they require me to use their templates.
  7. #7
    Luminous Being tzframpton's Avatar
    tzframpton's Computer Details
    HP Zbook
    Multi-disciplinary
    tzframpton's Discipline Details
    BIM Specialist
    Multi-disciplinary
    Full Virtual Design and Construction BIM services for the MEP engineering and construction industries.
    Revit 2019
    Mar 2006
    Dallas, TX - USA
    9,140
    Our Plot Style and Plotter directories are read-only, so I copied the entire directory to our full write-access mapped drive. Then I copied my profile and changed those directory paths for this same problem. It's very rare that I need to do this, but when you do need it and can't, it gets really annoying so this was my workaround.
    Tannar Z. Frampton ™ | Frampton & Associates, Inc.
  8. #8
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,715
    Pretty sure the PC3 is part of the Config File settings this can be changed on the fly using a lisp or just config. "Printer configuration search path"
    Code:
    (vl-load-com)
    (setq *files*  (vla-get-files  (vla-get-preferences (vlax-get-Acad-object))))
    (vla-put-PrinterConfigPath *files* "P:\\AutoDESK\\Plotting\\Plot Styles 2011")
  9. #9
    Win 7
    Architectural
    CAD Manager
    Architectural
    AutoCAD 2012
    Jun 2012
    London, UK
    86
    Thanks for the comments. Yes it is a shared location, although it is stored locally via login scripts with updates pulled through at login from the network. It was not my prefered choice of set up but IT security restrictions on group policies for standard users and poor network speeds forced this method to maximise performance and enable users easier access to their bak files, etc. The problem only affects the windows system printer.pc3 again it is IT restrictions to the printer preferences that have complicated the settings.
    I have the plotter config path defined as:
    Code:
    (setenv "PrinterConfigDir" "c:\\acad\\ACAD-2012-LOCAL\\02-Plotters\\")
    I'll try BIGAL's suggestion to see if that will work in conjunction with my existing settings.
  1. Copyclip from fix location and paste in desired location Autocad
    By subodh_gis in forum AutoLISP, Visual LISP & DCL
    Last Post: 3rd Oct 2013, 06:07 pm
  2. Flatshot location not at model location
    By ElRetro in forum AutoCAD General
    Last Post: 16th May 2013, 08:24 pm
  3. Forum temporary closure
    By CADTutor in forum News, Announcements & FAQ
    Last Post: 23rd Mar 2009, 11:17 am
  4. Storage location of temporary render images
    By Autodesk in forum AutoCAD RSS Feeds
    Last Post: 2nd Feb 2007, 02:14 am
  5. Temporary Osnap feature
    By Cadkiller in forum AutoCAD Drawing Management & Output
    Last Post: 9th Apr 2006, 07:02 pm
