igreere Posted October 13, 2013 Share Posted October 13, 2013 Hello. I started drawing a polyline and I do not know what I did to it, but now I can no longer draw lines, but rectangles /half circles etc. The picture will show it clear. What is the solution to this? Thank you. Quote Link to comment Share on other sites More sharing options...
ReMark Posted October 13, 2013 Share Posted October 13, 2013 Half circles would be created as a result of using the ARC option. Rectangles? Any chance you assigned a WIDTH to your polyline and have the FILLMODE option turned off? Quote Link to comment Share on other sites More sharing options...
igreere Posted October 13, 2013 Author Share Posted October 13, 2013 The circles, yes, I drew using the ARC command. As far as lines are concerned, I guess I assigned a width. Point is - how do I come back to normal lines? Quote Link to comment Share on other sites More sharing options...
ReMark Posted October 13, 2013 Share Posted October 13, 2013 You guessed you assigned a width? Why not check? Type PLINEWID at the command line and press Enter. What does AutoCAD return as a value? While you are at it type FILLMODE at the command line then press Enter. Is it set to a value of "1"? Quote Link to comment Share on other sites More sharing options...
igreere Posted October 13, 2013 Author Share Posted October 13, 2013 OK, the PLINEWID solved the problem. I had a width of 106 units. I entered value 0 and now it's ok. Thank you Quote Link to comment Share on other sites More sharing options...
