Xref bind error
Try following these steps on both the file you are working in and the file you are trying to Bind.
Process to remove corruption:
  1. Open file
  2. From the command prompt type: -PURGE (then select "R" for Reggapps, then hit [ENTER], then select "N" for no on running through each individual instance and then again [ENTER])
  3. From the command prompt type: -PURGE (then select "A" for All, then hit [ENTER], then select "N" for no on running through each individual instance and then again [ENTER])
  4. From the command prompt type: AUDIT (then select "Y" for Yes, then hit [ENTER])
  5. Save the drawing file
  6. Open a new blank drawing file
  7. From the command prompt type: INSERT (then select the drawing file affected that you just use the above process on, make sure it is set to insert at 0,0,0 and explode upon insertion in the check box)
  8. From the command prompt type: -PURGE (then select "R" for Reggapps, then hit [ENTER], then select "N" for no on running through each individual instance and then again [ENTER])
  9. From the command prompt type: -PURGE (then select "A" for All, then hit [ENTER], then select "N" for no on running through each individual instance and then again [ENTER])
  10. From the command prompt type: AUDIT (then select "Y" for Yes, then hit [ENTER])
  11. Save the drawing file
You still haven't answered my question. Can you Bind OTHER Xrefs in OTHER drawings?
You will have to trial and error to find the troublesome part of the drawing, AFAIK.
What you are saying doesn't make sense. There is a total of 12 XREFs in Hydrpo1a. Which one is the one that you cannot bind? You really need to provide more information in order for anyone to help you.
Edited by RobDraw
