jchandler5008 Posted October 17, 2013 Share Posted October 17, 2013 Having an issue with AutoCAD 2011. When i type in the options command "op", the options window doesn't appear and the drawing is frozen until I hit escape. I tried opening the options window from the drop down menu and the same thing happened. I closed out, rebooted and still have the same issue. I am using two monitors - so thought maybe the window got lost somewhere but can't seem to find it. Any ideas? Quote Link to comment Share on other sites More sharing options...
Tiger Posted October 17, 2013 Share Posted October 17, 2013 when you think you have Options open, hit Shift+Alt+Blankspace and then M (for Move) and then you can use the arrowkeys to move the window back. That is, if it's off hiding somewhere. Quote Link to comment Share on other sites More sharing options...
jchandler5008 Posted October 17, 2013 Author Share Posted October 17, 2013 Worked perfectly. Thank you! Quote Link to comment Share on other sites More sharing options...
