Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 25
    Senior Member CafeJr's Avatar
    AutoCAD 2010
    Oct 2013
    Brazil, São Paulo, Sorocaba
    216
    Default Filling up one area with a "oriented" polyline.
    Hello guys,
    Someone knows if's possible I fill up one area, as the picture, with one polyline oriented (or as a guided line), informing the lisp code the initial point, the radius of return line, and the space limits (as the limits line), horizontal or vertical to guide the lines until the whole area it's completely filled up?...
    Thanks in advance...
    Super Member marko_ribar's Avatar
    marko_ribar's Computer Details
    Windows 7 Ultimate X64
    Intel quad core CPU 4x2.66GHz, 8GB RAM
    INTEL compatibile
    quad core 4x2.66GHz
    8GB
    NVIDIA GeForce 6600 GT
    250 GB
    500 GB
    Samsung 17''
    Architectural
    marko_ribar's Discipline Details
    Architecture, project designer, project visualisation
    Architectural
    space design - modeling and animations
    AutoCAD 2014
    Feb 2010
    Belgrade, Serbia, Europe
    1,233
    This is my version, but I don't know what do you think - it may in some cases be shorter or longer fill than the opposite boundary edge (end of snake)...
    Code:
    (defun c:snakefill (/ ptlst lxm uxm lym rym p1 p2 p3 p4 ip r d1 d2 d3 d4 dmin dir dx dy ls lr lx ly n ss)
      (prompt "\nPick area...(lower-left corner+upper-right corner)")
      (command "_.rectangle" pause pause)
      (setq ptlst (mapcar 'cdr (vl-remove-if-not '(lambda (x) (eq (car x) 10)) (entget (entlast)))))
      (setq ptlst (mapcar '(lambda (x) (trans x (entlast) 1)) ptlst))
      (prompt "\nDelta X of OCS: ") (princ (distance (car ptlst) (cadr ptlst)))
      (prompt "\nDelta Y of OCS: ") (princ (distance (cadr ptlst) (caddr ptlst)))
      (initget 4)
      (setq lxm (getdist "\nPick lower X of OCS offset margin <0.0>: "))
      (if (null lxm) (setq lxm 0.0))
      (initget 4)
      (setq uxm (getdist "\nPick upper X of OCS offset margin <0.0>: "))
      (if (null uxm) (setq uxm 0.0))
      (initget 4)
      (setq lym (getdist "\nPick left Y of OCS offset margin <0.0>: "))
      (if (null lym) (setq lym 0.0))
      (initget 4)
      (setq rym (getdist "\nPick right Y of OCS offset margin <0.0>: "))
      (if (null rym) (setq rym 0.0))
      (setq p1 (mapcar '+ (car ptlst) (list lym lxm)))
      (setq p2 (mapcar '+ (cadr ptlst) (list (- rym) lxm)))
      (setq p3 (mapcar '+ (caddr ptlst) (list (- rym) (- uxm))))
      (setq p4 (mapcar '+ (cadddr ptlst) (list lym (- uxm))))
      (setq ip (getpoint "\nPick start point of snake fill: "))
      (initget 7)
      (setq r (getdist "\nPick radius of snake fill: "))
      (setq d1 (distance ip p1) d2 (distance ip p2) d3 (distance ip p3) d4 (distance ip p4))
      (setq dmin (min d1 d2 d3 d4))
      (initget 1 "X Y")
      (setq dir (getkword "\nSnake direction - parallel to X or Y of OCS (X/Y): "))
      (if (equal dmin d1)
          (setq dx (car (mapcar '- ip p1)))
          (setq dy (cadr (mapcar '- ip p1)))
          (if (eq dir "X")
              (setq ls (- (distance p1 p2) dx r))
              (setq lr (- (distance p1 p2) (* r 2.0)))
              (setq ly (- (distance p1 p4) dy))
              (setq n (fix (/ ly (* r 2.0))))
              (command "_.pline" ip (polar ip 0.0 ls) "a" "s" (mapcar '+ (polar ip 0.0 ls) (list r r)) (mapcar '+ (polar ip 0.0 ls) (list 0.0 (* r 2.0))) "")
              (setq ss (ssadd))
              (ssadd (entlast) ss)
              (command "_.pline" (mapcar '+ (polar ip 0.0 ls) (list 0.0 (* r 2.0))) (polar (mapcar '+ (polar ip 0.0 ls) (list 0.0 (* r 2.0))) pi lr) "a" "s" (mapcar '+ (polar (mapcar '+ (polar ip 0.0 ls) (list 0.0 (* r 2.0))) pi lr) (list (- r) r)) (mapcar '+ (polar (mapcar '+ (polar ip 0.0 ls) (list 0.0 (* r 2.0))) pi lr) (list 0.0 (* r 2.0))) "l" (polar (mapcar '+ (polar (mapcar '+ (polar ip 0.0 ls) (list 0.0 (* r 2.0))) pi lr) (list 0.0 (* r 2.0))) 0.0 lr) "a" "s" (mapcar '+ (polar (mapcar '+ (polar (mapcar '+ (polar ip 0.0 ls) (list 0.0 (* r 2.0))) pi lr) (list 0.0 (* r 2.0))) 0.0 lr) (list r r)) (mapcar '+ (polar (mapcar '+ (polar (mapcar '+ (polar ip 0.0 ls) (list 0.0 (* r 2.0))) pi lr) (list 0.0 (* r 2.0))) 0.0 lr) (list 0.0 (* r 2.0))) "")
              (repeat (- (fix (/ n 2.0)) 1)
                (command "_.copy" (entlast) "" '(0.0 0.0 0.0) (list 0.0 (* r 4.0) 0.0))
              (setq ls (- (distance p1 p4) dy r))
              (setq lr (- (distance p1 p4) (* r 2.0)))
              (setq lx (- (distance p1 p2) dx))
              (setq n (fix (/ lx (* r 2.0))))
              (command "_.pline" ip (polar ip (* pi 0.5) ls) "a" "s" (mapcar '+ (polar ip (* pi 0.5) ls) (list r r)) (mapcar '+ (polar ip (* pi 0.5) ls) (list (* r 2.0) 0.0)) "")
              (setq ss (ssadd))
              (command "_.pline" (mapcar '+ (polar ip (* pi 0.5) ls) (list (* r 2.0) 0.0)) (polar (mapcar '+ (polar ip (* pi 0.5) ls) (list (* r 2.0) 0.0)) (* pi -0.5) lr) "a" "s" (mapcar '+ (polar (mapcar '+ (polar ip (* pi 0.5) ls) (list (* r 2.0) 0.0)) (* pi -0.5) lr) (list r (- r))) (mapcar '+ (polar (mapcar '+ (polar ip (* pi 0.5) ls) (list (* r 2.0) 0.0)) (* pi -0.5) lr) (list (* r 2.0) 0.0)) "l" (polar (mapcar '+ (polar (mapcar '+ (polar ip (* pi 0.5) ls) (list (* r 2.0) 0.0)) (* pi -0.5) lr) (list (* r 2.0) 0.0)) (* pi 0.5) lr) "a" "s" (mapcar '+ (polar (mapcar '+ (polar (mapcar '+ (polar ip (* pi 0.5) ls) (list (* r 2.0) 0.0)) (* pi -0.5) lr) (list (* r 2.0) 0.0)) (* pi 0.5) lr) (list r r)) (mapcar '+ (polar (mapcar '+ (polar (mapcar '+ (polar ip (* pi 0.5) ls) (list (* r 2.0) 0.0)) (* pi -0.5) lr) (list (* r 2.0) 0.0)) (* pi 0.5) lr) (list (* r 2.0) 0.0)) "")
                (command "_.copy" (entlast) "" '(0.0 0.0 0.0) (list (* r 4.0) 0.0 0.0))
      (if (equal dmin d2)
          (setq dx (car (mapcar '- p2 ip)))
          (setq dy (cadr (mapcar '- ip p2)))
          (if (eq dir "X")
              (setq ls (- (distance p2 p1) dx r))
              (setq lr (- (distance p2 p1) (* r 2.0)))
              (setq ly (- (distance p2 p3) dy))
              (command "_.pline" ip (polar ip pi ls) "a" "s" (mapcar '+ (polar ip pi ls) (list (- r) r)) (mapcar '+ (polar ip pi ls) (list 0.0 (* r 2.0))) "")
              (setq ss (ssadd))
              (command "_.pline" (mapcar '+ (polar ip pi ls) (list 0.0 (* r 2.0))) (polar (mapcar '+ (polar ip pi ls) (list 0.0 (* r 2.0))) 0.0 lr) "a" "s" (mapcar '+ (polar (mapcar '+ (polar ip pi ls) (list 0.0 (* r 2.0))) 0.0 lr) (list r r)) (mapcar '+ (polar (mapcar '+ (polar ip pi ls) (list 0.0 (* r 2.0))) 0.0 lr) (list 0.0 (* r 2.0))) "l" (polar (mapcar '+ (polar (mapcar '+ (polar ip pi ls) (list 0.0 (* r 2.0))) 0.0 lr) (list 0.0 (* r 2.0))) pi lr) "a" "s" (mapcar '+ (polar (mapcar '+ (polar (mapcar '+ (polar ip pi ls) (list 0.0 (* r 2.0))) 0.0 lr) (list 0.0 (* r 2.0))) pi lr) (list (- r) r)) (mapcar '+ (polar (mapcar '+ (polar (mapcar '+ (polar ip pi ls) (list 0.0 (* r 2.0))) 0.0 lr) (list 0.0 (* r 2.0))) pi lr) (list 0.0 (* r 2.0))) "")
              (setq ls (- (distance p2 p3) dy r))
              (setq lr (- (distance p2 p3) (* r 2.0)))
              (command "_.pline" ip (polar ip (* pi 0.5) ls) "a" "s" (mapcar '+ (polar ip (* pi 0.5) ls) (list (- r) r)) (mapcar '+ (polar ip (* pi 0.5) ls) (list (* r -2.0) 0.0)) "")
              (setq ss (ssadd))
              (command "_.pline" (mapcar '+ (polar ip (* pi 0.5) ls) (list (* r -2.0) 0.0)) (polar (mapcar '+ (polar ip (* pi 0.5) ls) (list (* r -2.0) 0.0)) (* pi -0.5) lr) "a" "s" (mapcar '+ (polar (mapcar '+ (polar ip (* pi 0.5) ls) (list (* r -2.0) 0.0)) (* pi -0.5) lr) (list (- r) (- r))) (mapcar '+ (polar (mapcar '+ (polar ip (* pi 0.5) ls) (list (* r -2.0) 0.0)) (* pi -0.5) lr) (list (* r -2.0) 0.0)) "l" (polar (mapcar '+ (polar (mapcar '+ (polar ip (* pi 0.5) ls) (list (* r -2.0) 0.0)) (* pi -0.5) lr) (list (* r -2.0) 0.0)) (* pi 0.5) lr) "a" "s" (mapcar '+ (polar (mapcar '+ (polar (mapcar '+ (polar ip (* pi 0.5) ls) (list (* r -2.0) 0.0)) (* pi -0.5) lr) (list (* r -2.0) 0.0)) (* pi 0.5) lr) (list (- r) r)) (mapcar '+ (polar (mapcar '+ (polar (mapcar '+ (polar ip (* pi 0.5) ls) (list (* r -2.0) 0.0)) (* pi -0.5) lr) (list (* r -2.0) 0.0)) (* pi 0.5) lr) (list (* r -2.0) 0.0)) "")
                (command "_.copy" (entlast) "" '(0.0 0.0 0.0) (list (* r -4.0) 0.0 0.0))
      (if (equal dmin d3)
          (setq dx (car (mapcar '- p3 ip)))
          (setq dy (cadr (mapcar '- p3 ip)))
          (if (eq dir "X")
              (setq ls (- (distance p3 p4) dx r))
              (setq lr (- (distance p3 p4) (* r 2.0)))
              (setq ly (- (distance p3 p2) dy))
              (command "_.pline" ip (polar ip pi ls) "a" "s" (mapcar '+ (polar ip pi ls) (list (- r) (- r))) (mapcar '+ (polar ip pi ls) (list 0.0 (* r -2.0))) "")
              (setq ss (ssadd))
              (command "_.pline" (mapcar '+ (polar ip pi ls) (list 0.0 (* r -2.0))) (polar (mapcar '+ (polar ip pi ls) (list 0.0 (* r -2.0))) 0.0 lr) "a" "s" (mapcar '+ (polar (mapcar '+ (polar ip pi ls) (list 0.0 (* r -2.0))) 0.0 lr) (list r (- r))) (mapcar '+ (polar (mapcar '+ (polar ip pi ls) (list 0.0 (* r -2.0))) 0.0 lr) (list 0.0 (* r -2.0))) "l" (polar (mapcar '+ (polar (mapcar '+ (polar ip pi ls) (list 0.0 (* r -2.0))) 0.0 lr) (list 0.0 (* r -2.0))) pi lr) "a" "s" (mapcar '+ (polar (mapcar '+ (polar (mapcar '+ (polar ip pi ls) (list 0.0 (* r -2.0))) 0.0 lr) (list 0.0 (* r -2.0))) pi lr) (list (- r) (- r))) (mapcar '+ (polar (mapcar '+ (polar (mapcar '+ (polar ip pi ls) (list 0.0 (* r -2.0))) 0.0 lr) (list 0.0 (* r -2.0))) pi lr) (list 0.0 (* r -2.0))) "")
                (command "_.copy" (entlast) "" '(0.0 0.0 0.0) (list 0.0 (* r -4.0) 0.0))
              (setq ls (- (distance p3 p2) dy r))
              (setq lr (- (distance p3 p2) (* r 2.0)))
              (setq lx (- (distance p3 p4) dx))
              (command "_.pline" ip (polar ip (* pi -0.5) ls) "a" "s" (mapcar '+ (polar ip (* pi -0.5) ls) (list (- r) (- r))) (mapcar '+ (polar ip (* pi -0.5) ls) (list (* r -2.0) 0.0)) "")
              (setq ss (ssadd))
              (command "_.pline" (mapcar '+ (polar ip (* pi -0.5) ls) (list (* r -2.0) 0.0)) (polar (mapcar '+ (polar ip (* pi -0.5) ls) (list (* r -2.0) 0.0)) (* pi 0.5) lr) "a" "s" (mapcar '+ (polar (mapcar '+ (polar ip (* pi -0.5) ls) (list (* r -2.0) 0.0)) (* pi 0.5) lr) (list (- r) r)) (mapcar '+ (polar (mapcar '+ (polar ip (* pi -0.5) ls) (list (* r -2.0) 0.0)) (* pi 0.5) lr) (list (* r -2.0) 0.0)) "l" (polar (mapcar '+ (polar (mapcar '+ (polar ip (* pi -0.5) ls) (list (* r -2.0) 0.0)) (* pi 0.5) lr) (list (* r -2.0) 0.0)) (* pi -0.5) lr) "a" "s" (mapcar '+ (polar (mapcar '+ (polar (mapcar '+ (polar ip (* pi -0.5) ls) (list (* r -2.0) 0.0)) (* pi 0.5) lr) (list (* r -2.0) 0.0)) (* pi -0.5) lr) (list (- r) (- r))) (mapcar '+ (polar (mapcar '+ (polar (mapcar '+ (polar ip (* pi -0.5) ls) (list (* r -2.0) 0.0)) (* pi 0.5) lr) (list (* r -2.0) 0.0)) (* pi -0.5) lr) (list (* r -2.0) 0.0)) "")
      (if (equal dmin d4)
          (setq dx (car (mapcar '- ip p4)))
          (setq dy (cadr (mapcar '- p4 ip)))
          (if (eq dir "X")
              (setq ls (- (distance p4 p3) dx r))
              (setq lr (- (distance p4 p3) (* r 2.0)))
              (setq ly (- (distance p4 p1) dy))
              (command "_.pline" ip (polar ip 0.0 ls) "a" "s" (mapcar '+ (polar ip 0.0 ls) (list r (- r))) (mapcar '+ (polar ip 0.0 ls) (list 0.0 (* r -2.0))) "")
              (setq ss (ssadd))
              (command "_.pline" (mapcar '+ (polar ip 0.0 ls) (list 0.0 (* r -2.0))) (polar (mapcar '+ (polar ip 0.0 ls) (list 0.0 (* r -2.0))) pi lr) "a" "s" (mapcar '+ (polar (mapcar '+ (polar ip 0.0 ls) (list 0.0 (* r -2.0))) pi lr) (list (- r) (- r))) (mapcar '+ (polar (mapcar '+ (polar ip 0.0 ls) (list 0.0 (* r -2.0))) pi lr) (list 0.0 (* r -2.0))) "l" (polar (mapcar '+ (polar (mapcar '+ (polar ip 0.0 ls) (list 0.0 (* r -2.0))) pi lr) (list 0.0 (* r -2.0))) 0.0 lr) "a" "s" (mapcar '+ (polar (mapcar '+ (polar (mapcar '+ (polar ip 0.0 ls) (list 0.0 (* r -2.0))) pi lr) (list 0.0 (* r -2.0))) 0.0 lr) (list r (- r))) (mapcar '+ (polar (mapcar '+ (polar (mapcar '+ (polar ip 0.0 ls) (list 0.0 (* r -2.0))) pi lr) (list 0.0 (* r -2.0))) 0.0 lr) (list 0.0 (* r -2.0))) "")
              (setq ls (- (distance p4 p1) dy r))
              (setq lr (- (distance p4 p1) (* r 2.0)))
              (setq lx (- (distance p4 p3) dx))
              (command "_.pline" ip (polar ip (* pi -0.5) ls) "a" "s" (mapcar '+ (polar ip (* pi -0.5) ls) (list r (- r))) (mapcar '+ (polar ip (* pi -0.5) ls) (list (* r 2.0) 0.0)) "")
              (setq ss (ssadd))
              (command "_.pline" (mapcar '+ (polar ip (* pi -0.5) ls) (list (* r 2.0) 0.0)) (polar (mapcar '+ (polar ip (* pi -0.5) ls) (list (* r 2.0) 0.0)) (* pi 0.5) lr) "a" "s" (mapcar '+ (polar (mapcar '+ (polar ip (* pi -0.5) ls) (list (* r 2.0) 0.0)) (* pi 0.5) lr) (list r r)) (mapcar '+ (polar (mapcar '+ (polar ip (* pi -0.5) ls) (list (* r 2.0) 0.0)) (* pi 0.5) lr) (list (* r 2.0) 0.0)) "l" (polar (mapcar '+ (polar (mapcar '+ (polar ip (* pi -0.5) ls) (list (* r 2.0) 0.0)) (* pi 0.5) lr) (list (* r 2.0) 0.0)) (* pi -0.5) lr) "a" "s" (mapcar '+ (polar (mapcar '+ (polar (mapcar '+ (polar ip (* pi -0.5) ls) (list (* r 2.0) 0.0)) (* pi 0.5) lr) (list (* r 2.0) 0.0)) (* pi -0.5) lr) (list r (- r))) (mapcar '+ (polar (mapcar '+ (polar (mapcar '+ (polar ip (* pi -0.5) ls) (list (* r 2.0) 0.0)) (* pi 0.5) lr) (list (* r 2.0) 0.0)) (* pi -0.5) lr) (list (* r 2.0) 0.0)) "")
      (command "_.pedit" "m" ss "" "j" "" "")
    M.R.
    Marko Ribar, d.i.a. (graduated engineer of architecture)
    M.R. on YouTube
    Luminous Being
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    9,901
    This is close also lines can be any angel etc done for chevrons in road islands just create an inner polygon
    Code:
    ; this use the extrim command to trim shape
    ; By Alan H Jan 2012
    (defun C:Chevron ( / obj pt1 pt2 pt3 pt4 newpt1 newpt2 )
    (acet-error-init (list
                       (list   "cmdecho" 0
                             "highlight" 0
                             "regenmode" 1
                                "osmode" 0
                               "ucsicon" 0
                            "offsetdist" 0
                                "attreq" 0
                              "plinewid" 0
                             "plinetype" 1
                              "gridmode" 0
                               "celtype" "CONTINUOUS"
                             "ucsfollow" 0
                              "limcheck" 0
                       T     ;flag. True means use undo for error clean up.
                       '(if redraw_it (redraw na 4))
                      );list
    );acet-error-init
    (setq obj (car (entsel "\nPick pline or circle")))
    ; should do a object test here
    (setq whatis (cdr (assoc 0 (entget obj))))
    (if (= whatis "LWPOLYLINE")
    (princ "\You have picked something other than a polyline ")
    (princ "\Remake into a pline and do again ")
    (setq dummy (getstring "\press any key"))
    (exit)
    ) ; progn
    ) ; if
    (setq pt1 (Getpoint "\nPick Line start point"))
    (setq pt2 (Getpoint pt1 "\nPick end point"))
    (command "line" pt1 pt2 "")
    (setq gap1 (getreal "\nenter spacing 1"))
    (setq gap2 (getreal "\nenter spacing 2"))
    (setq pt3 (getpoint "\nPick 1st cross point"))
    (setq pt4 (getpoint pt3 "\nPick 2nd cross point"))
    (setq dist (distance pt3 pt4))
    (setq x (fix (/ dist (+ gap1 gap2))))
    (setq newpt1 (strcat (rtos gap1 2 2) ",0.0"))
    (setq newpt2 (strcat (rtos gap2 2 2) ",0.0"))
    (repeat x
    (command "copy" "L" "" "0,0" newpt1)
    (command "copy" "L" "" "0,0" newpt2)
    (load "Extrim")
    (etrim obj pt1)
    (acet-error-restore)
    ) ; end defun
    AutoCAD 2010
    Oct 2013
    216
    Quote Originally Posted by marko_ribar View Post
    M.R.
    Marko_ribar, thanks for help me, the code that you wrote it's almost that I need, but the lines are drawed only in a regular region (rectangle)? It's possible select other kind of region? And as the picture, the arcs following the limits of inclination... I was thinking in some thing like I fill up the region following the limits using as a "rule" to drawing the line, like: if the start point was inserted it's possible to draw the line until the limit line and where we get crossing point of the limit line (green line) it could be decreased to creat the end of first line using the radius as a reference, after that drawing the arc and follow again the "rule", doing it until the end of drawing, but I don't know if's possible work in this way.
    Thank's again and sorry about the english!...
  5. #5
    AutoCAD 2010
    Oct 2013
    216
    Quote Originally Posted by BIGAL View Post
    BIGAL, thanks, I don't know if I'm doing it wrong, but using your code I create only lines following the region (outline), is it correct?...
  6. #6
    Luminous Being
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    9,901
    Yes only uses 1 pline but it can have arcs etc
  7. #7
    Lee Mac's Computer Details
    Windows 7 Ultimate (32-bit)
    Multi-disciplinary
    Lee Mac's Discipline Details
    Multi-disciplinary
    AutoCAD 2013
    Aug 2008
    London, England
    19,368
    This request reminds me of this thread - perhaps that program may help.
    Lee Mac ProgrammingTwitterExchange App StoreDropbox (500MB free)
  8. #8
    AutoCAD 2010
    Oct 2013
    216
    Quote Originally Posted by Lee Mac View Post
    Lee Mac is almost that... but, I'm filling up a irregular region!... I'm showing another drawing to explain about it...
  9. #9
    Luminous Being
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    9,901
    It is solvable but its not a quick task, so I am only offering maybe a method Lee may be able to help with code
    offset outside pline as required
    create line at required angle and spacing (see my chevron.lsp) trim to new inner pline
    using a list of the lines left to right just alternate the fillet command top and bottom
    should look like image.
  10. #10
    AutoCAD 2010
    Oct 2013
    216
    Thanks Bigal...
  1. Replies: 21
    Last Post: 14th Jul 2014, 07:04 am
  2. Replies: 1
    Last Post: 4th Jan 2011, 07:59 pm
  3. Re-draw an object using polyline from nodes created by "divide" command
    By pryzmm in forum AutoLISP, Visual LISP & DCL
    Last Post: 21st Aug 2010, 05:12 am
  4. Problem with "Filling"
    By Richo in forum SketchUp
    Last Post: 26th Jul 2010, 08:32 pm
  5. How to make an area "Striped"?
    By RingSteel in forum AutoCAD Beginners' Area
    Last Post: 10th Jun 2009, 06:10 pm
Tags for this Thread
