CafeJr Posted October 21, 2013 Share Posted October 21, 2013 Guys, I got this code, to do a multiple offset, it works good, but I need to do one complementation in that, the direction of final objects, the code doesn't allow you choose it, every time the code draw the offset line above of objects, It's possible fix it? Indicating the direction of end offset lines... Thanks in advance... (defun c:mo (/ plines ; selection set of polylines ext ; extrnal point dist ; distance to offset poly ; a polyline from plines plist ; the list of poly del ; polyline to delete int ; internal point i layer) (command "undo" "begin") (princ "select polylines") (setq plines (ssget) i 0 ext (getvar "limmax") dist (getdist "distance = ") ) (repeat (sslength plines) (setq poly (ssname plines i)) (setq plist (entget poly)) (command "offset" dist poly ext "") ;(setq del (entlast) ;int (polar ;(cdr (assoc 10 (entget del))) ;(angle ;(cdr (assoc 10 (entget del))) ;(cdr (assoc 10 plist))) ;(* 2 (distance (cdr (assoc 10 plist)) ;(cdr (assoc 10 (entget del))))))) ;(command "offset" dist poly int "") ;(entdel del) (setq i (1+ i)) ) (command "undo" "end") (if (= "Y" (strcase (getstring "\ndelete initial polylines? (Y/N) = ")) ) (command "erase" plines "") ) ) Quote Link to comment Share on other sites More sharing options...
CheSyn Posted October 21, 2013 Share Posted October 21, 2013 Untested, but should fix the issue. I changed "ext" (added getpoint) and "dist" (added \n) (defun c:mo (/ plines ; selection set of polylines ext ; extrnal point dist ; distance to offset poly ; a polyline from plines plist ; the list of poly del ; polyline to delete int ; internal point i layer) (command "undo" "begin") (princ "select polylines") (setq plines (ssget) i 0 ext (getpoint "\nSelect the offset direction") dist (getdist "\ndistance = ") ) (repeat (sslength plines) (setq poly (ssname plines i)) (setq plist (entget poly)) (command "offset" dist poly ext "") ;(setq del (entlast) ;int (polar ;(cdr (assoc 10 (entget del))) ;(angle ;(cdr (assoc 10 (entget del))) ;(cdr (assoc 10 plist))) ;(* 2 (distance (cdr (assoc 10 plist)) ;(cdr (assoc 10 (entget del))))))) ;(command "offset" dist poly int "") ;(entdel del) (setq i (1+ i)) ) (command "undo" "end") (if (= "Y" (strcase (getstring "\ndelete initial polylines? (Y/N) = ")) ) (command "erase" plines "") ) ) Quote Link to comment Share on other sites More sharing options...
CafeJr Posted October 21, 2013 Author Share Posted October 21, 2013 Untested, but should fix the issue. I changed "ext" (added getpoint) and "dist" (added \n) Tested!... Thanks CheSyn!... Works well!!!... Quote Link to comment Share on other sites More sharing options...
the lagman Posted February 7, 2014 Share Posted February 7, 2014 HI to all! Is there a way to add to the above code the ability to change the layer also of the offset objects?? Thanks in advance! Quote Link to comment Share on other sites More sharing options...
MSasu Posted March 6, 2014 Share Posted March 6, 2014 To change the layer of newly created polylines (adjust part in blue to suit your case): ... (setq plist (entget poly)) (command "offset" dist poly ext "") [color=magenta](command "_CHPROP" (entlast) "" "_LA" "[color=blue]NameOfTargetLayer[/color]" "")[/color] ... Quote Link to comment Share on other sites More sharing options...
the lagman Posted March 7, 2014 Share Posted March 7, 2014 To change the layer of newly created polylines (adjust part in blue to suit your case): ... (setq plist (entget poly)) (command "offset" dist poly ext "") [color=magenta](command "_CHPROP" (entlast) "" "_LA" "[color=blue]NameOfTargetLayer[/color]" "")[/color] ... Wow thank you so much! Really appreciate your help! Works exactly as needed! Quote Link to comment Share on other sites More sharing options...
MSasu Posted March 8, 2014 Share Posted March 8, 2014 You're entirely welcome! Quote Link to comment Share on other sites More sharing options...
