Page 1 of 5 1 2 3 ... LastLast
Results 1 to 10 of 49
    Junior Member
    AutoCAD 2011
    Oct 2013
    19
    Smile Help needed with a Macro please
    Hi All
    I cave created a new drop down menu using the Customize User Interface in AutoCad 2011 called Load Aerial Photography with a sub menu called Insert Tiles.
    When selecting my new menu I would like to have a macro that browses to where our JPEG Aerial Photos are kept on our network.
    At the moment I have to select the AutoCad pull down:-
    Insert, Raster Image Referance then browse to M:\DATA\AERIAL_PHOTOS\2012\84235\RGB_10cm_1km_Jpeg _Tiles
    If there is a user on this Forum who can put together a Macro that will browse to the above filepath I would be very grateful as I'm really getting nowhere with this.
    Thanks
    Paul
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,865
    Is it possible that the slashes have to go the other way? Like this: / instead of like this \.
    According to a reference book I have the "/" character is used to define directories. Ex. - C:/0000/bolt.dwg
    Junior Member
    AutoCAD 2011
    Oct 2013
    19
    The example I have given Isnt my attempt at writing the Macro its the long handed way of inserting a raster image into a drawing, what I need is someone with Macro experiance to put together a piece of Macro code that will look to the file path I have provided, hope that makes sense.
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,865
    You are writing a path to a directory. Reverse the slash.
  5. #5
    Junior Member
    AutoCAD 2011
    Oct 2013
    19
    Thats the point i'm not writing anything as I don't have the experiance to write Macros, if you look at a macro it has instructins like (defun c:/ (((****)) etc
  6. #6
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,865
    If you are looking at something like this...
    (defun c:addtxt ( / i n r s )
    ...then aren't you using a lisp routine not a macro?
  7. #7
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,865
    Here is an example of a complex macro (courtesy of CADTech Seminars).
    ^C^C_-layer;make;TAGS;color;red;;;_-insert;c:/blocks/tag.dwg;\96;96;;\_insert;c:/blocks/scale96.dwg;$m=$(getvar,lastpoint);96;96;;_pline;$m=$(getvar,lastpoint);w;1;;\;_insert;c:/block/tag2.dwg;end;\96;96;;\\plinewid;0;
  8. #8
    Junior Member
    AutoCAD 2011
    Oct 2013
    19
    This is c copy from my CUI where it says Macro in the properties box (if c:a4comm nil (load "c:/data/lisp/a4comm"));a4comm;
  9. #9
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,865
    That macro is calling a lisp routine. Do you know what a lisp routine is?
  10. #10
    Junior Member
    AutoCAD 2011
    Oct 2013
    19
    Would you know how to put a Macro together that allow my to insert my JPEG using Insert, Raster Image Referance M:\DATA\AERIAL_PHOTOS\2012\84235\RGB_10cm_1km_Jpeg _Tiles?
  1. SELECT in macro won't stay selected!!!! How to hide Macro in command line aswell?
    By jamesfear in forum The CUI, Hatches, Linetypes, Scripts & Macros
    Last Post: 31st Jul 2012, 02:23 am
  2. help needed C3D
    By matt sad in forum AutoCAD 3D Modelling & Rendering
    Last Post: 29th Aug 2011, 12:29 pm
  3. Help needed please
    By Corner Post in forum AutoCAD Beginners' Area
    Last Post: 15th Feb 2007, 06:57 am
  4. some help needed
    By Rebbeca in forum AutoLISP, Visual LISP & DCL
    Last Post: 22nd Nov 2006, 06:27 pm
  5. 3d Solid Rotation VBA Macro Needed
    By handyandy in forum AutoLISP, Visual LISP & DCL
    Last Post: 9th Apr 2006, 10:52 pm
Tags for this Thread
