LT 2014 Sheet Set Manger Scale
Diesel
In the Field dialog, change Field Category to Objects, Field Names to Object, Object Type use the Select button to select your Viewport, the select the desired property.
Thanks for the answer. I asked because I may be installing 2014 LT in a few days. Appreciated.
