Increasing the amount of viewports available
PotGuy
Hey all, just a quick one.
What was the command to increase the amount of viewports that were active in one paper space tab?
Currently hit the default limit.
Man Dadgad you were quick off the mark there :o
I'm not sure if there is a maximum value, although as the value is an integer it would have a theoretical maximum of 32767 if they are using 16 bit integers.
I can second what Remark said. When in putting the command, when I put in 80, for example, it will state a value the value must be between 2 to 64.
