Results 1 to 3 of 3
    Full Member
    p0peye's Computer Details
    Win7
    HP EliteBook 8770w
    i7-3840QM
    32GB
    Nvidia Quadro K4000M
    HP ZR2440w
    AutoCAD 2014
    May 2013
    Belgrade, Serbia
    32
    Question Macro - Unknown command for any multiple command
    Hi all,
    I am encountering a strange problem:
    Which ever "multiple" command I enter - I get aforementioned error.
    Example
    Command: ^C^C_Selectsimilar;\;change;p;c;7;;
    Unknown command "^C^C_SELECTSIMILAR;\;CHANGE;P;C;7;;". Press F1 for help.
    gives me the same error.
    every multiple command I try to enter in command prompt - gives me the error.
    Among others, I tried the commands Tuns mentioned in another topic:
    Command: Select;p;;
    Unknown command "SELECT;P;;". Press F1 for help.
    Not to be odd enough - If I make a toolbar button and assign the very same macro to it - the press on the button executes the command(s) successfully
    I am new to macros and I need to experiment a bit before I "hit the pot" - so the solution with the buttons are not applicable.
    Any advice how to resolve this problem?
    Thanks in advance,
    cheers
    p.s. - F1 is a very nice button (in AC). Beautiful letter, number... Cute. It is a shame it don't have some cool function, like for example - useful help...
    Autocad 2014
    Advance Steel 2013
    Forum Deity steven-g's Avatar
    steven-g's Computer Details
    Win 7
    Construction
    steven-g's Discipline Details
    Draughtsman
    Construction
    I work in the estimating department of a large building contractor.
    AutoCAD 2018
    May 2013
    An Englishman in Belgium
    2,118
    Quote Originally Posted by p0peye View Post
    Welcome to CADTUTOR.
    Unfortunately that is how macros work, you cannot enter them directly at the command line, they have to be used in a tool-palette or in the CUI to create new commands. The theory is that a macro saves you time having to type all the commands out in sequence, so typing it at the command line would be pointless (other than testing but that isn't an option).
    How are you creating your tool-palette buttons - I have a tool-palette button called TEMP I just right click on it select properties and type in a macro in the 'command string' press OK and then click the button, it's a very quick method to try out new macro's.
    Full Member
    Win7
    HP EliteBook 8770w
    i7-3840QM
    32GB
    HP ZR2440w
    AutoCAD 2014
    May 2013
    Belgrade, Serbia
    32
    Hi Steven, now that you explained it - actually it makes sance...
    Thanks for the reply and a usefull tip.
    Cheers,
    N
  1. Macro command in command prompts shortcut?
    By Benjo in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 10th Feb 2011, 04:11 am
  2. Macro command in command prompts shortcut?
    By Benjo in forum The CUI, Hatches, Linetypes, Scripts & Macros
    Last Post: 8th Feb 2011, 05:57 pm
  3. Open and Save command causes "Unknown Command" error
    By andythoms in forum AutoCAD General
    Last Post: 12th Nov 2010, 05:00 pm
  4. Create a Command to run macro from command line
    By Andresig in forum AutoLISP, Visual LISP & DCL
    Last Post: 16th Sep 2010, 09:16 pm
  5. Unknown Command
    By slimjramirez in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 10th Mar 2008, 05:24 pm
Tags for this Thread
