Page 1 of 4 1 2 3 ... LastLast
Results 1 to 10 of 35
    Full Member
    jbgraphic's Computer Details
    win 7
    Z68
    i5 2500K
    8gig
    ati V4800
    Samsung 1T
    2 x Dell P2311h
    Civil 3D 2014
    Sep 2011
    Colorado
    62
    Default This problem is just bugging me it seems off.
    This is a problem from this text book http://www.cengage.com/search/produc...09572#Overview
    It just seems off to me and I can't get started on the drawing. The slanted face with the two holes is just giving me problems.
    INSTRUCTIONS
    These problems provide you with a dimensioned pictorial view.
    Use the given information to select and draw the necessary
    multiviews and auxiliary view or views. Do not draw the pictorial view. Set up your drawings with a properly sized
    border and title block. Properly complete the information in
    the title block. Do not draw the dimension
    This is what I have so far but it just seems wrong? This is just in the "construction" stage.
    P09 - 33.dwg
    Forum Deity steven-g's Avatar
    steven-g's Computer Details
    Win 7
    Construction
    steven-g's Discipline Details
    Draughtsman
    Construction
    I work in the estimating department of a large building contractor.
    AutoCAD 2018
    May 2013
    An Englishman in Belgium
    2,086
    Looking at the image I could only pick out one point that may be an issue, if you take that back edge and line it through, it doesn't line up with the front angled flange face, I would say it lines up to the back of it, which would make more sense anyway. They don't give you a thickness for that flange either, so I would guess at .31 , but you will need a side view to find the true plan thickness. It's difficult to describe (and I know nothing about engineering terms) but hopefully this image will show you what I mean - I could be wrong that's just how I read it.
    Forum Deity
    nestly's Computer Details
    Windows 7 Pro (64bit)
    AutoCAD 2015
    Sep 2010
    PA
    3,444
    I believe there are at least 3 dimensions missing to accurately reproduce the part.
    Inventor 2015
    Sep 2007
    Williamsport, PA
    8,725
    steven-g
    Your solution does not show 30° inclined plane.
    (or is that an image of the original OP's file - I didn't download it?)
  5. #5
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,602
    The slanted face appears to have a groove in it which you don't mention. One option would be to draw that as if it were a vertical face and when completed rotate it the required 30 degrees then union it to the remainder of the 3D model.
  6. #6
    Win 7
    Construction
    Draughtsman
    Construction
    AutoCAD 2018
    May 2013
    2,086
    Quote Originally Posted by JD Mather View Post
    steven-g
    Yes that image is just to highlight the comment I made, the OP's dwg file shows the top right hand corner as a point, which doesn't allow for the thickness of the upright. I didn't feel that the OP's question when viewed with his drawing warranted further comment on other items at the moment, he is doing OK so far. And was only asking about the basic plan view.
  7. #7
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,602
    How did you determine the angle of this line?
  8. #8
    Inventor 2015
    Sep 2007
    Williamsport, PA
    8,725
    This one is challenging.
    Hint: It's all about the partial auxiliary views True Size and Shape (TSS), (and assumption that that inclined feature is also .31, same as the base feature). Back in a while to show development of the solution.
    Oops, I think the designer made a mistake in location of the 1.5. The isometric only comes out looking like theirs if I dimension to the tangent with the cylinder rather than to the centerline.
  9. #9
    Full Member
    win 7
    Z68
    i5 2500K
    8gig
    ati V4800
    Samsung 1T
    2 x Dell P2311h
    Civil 3D 2014
    Sep 2011
    Colorado
    62
    Thanks guys.
    Some good help. I was not correctly "allowing" for the thickness of the slanted part.
  10. #10
    Inventor 2015
    Sep 2007
    Williamsport, PA
    8,725
    Quote Originally Posted by jbgraphic View Post
    Thanks guys.
    Attach your new solution. (Hint: I'll wager that you still aren't "correctly" allowing for the thickness.)
  1. [3dmax] Windows problem and realistic view problem :(
    By Mena__99 in forum 3ds Max General
    Last Post: 21st Sep 2013, 08:54 pm
  2. Replies: 2
    Last Post: 8th Dec 2011, 06:58 am
  3. Bold Text bugging me.
    By Skeeps in forum AutoCAD Drawing Management & Output
    Last Post: 8th Oct 2007, 12:23 pm
  4. This is bugging me... please help!
    By ChadPoehland in forum AutoCAD Drawing Management & Output
    Last Post: 27th Oct 2006, 09:23 am
