Results 1 to 8 of 8
    Junior Member
    not specified
    Jul 2006
    Tacoma, Washington
    23
    Default Figuring out angles
    I'm new to autocad and designing. I'm practicing with tutorials and one of them has me stumped. The site is
    http://we-r-here.com/cad/tutorials/level_1/1-4.htm
    I'm fine inputing info until it gives angles. I know that if I enter @D<A that should give me the right input but when I enter @1.4<150 it's not right. I then went into the command line input to see if I could back track to understand. The right way is @1.4<30 ... I'm figuring that the angle has to do with the WCS but how? How do you get to this point? How do I figure this out??? Please help I'm stumped and open to any, any, suggetions and helpful hints for a eager beginner. And please explain as simply as you can since I'm a very new beginner.
    Thanks , Anna
    Forum Deity
    not specified
    Jul 2004
    Anchorage, Alaska
    2,074
    The angle in AutoCAD is the angle from the x axis. 0 degrees is horizontal to the right. In the figure/example, 150 degrees is measured from the adjacent line; the angle of the line (relative to the x axis) is 30 degrees. So use @1.4<30 to draw that line (if going counterclockwise around the figure).
    Senior Member WagglyFawn's Avatar
    Inventor 2009
    Jul 2006
    Washington State
    186
    AutoCAD's default settings have angles starting at 0 degrees East going counter-clockwise. Or as CarlB said, start to the right. I doubt you'll ever need to change this too, so once you do enough you'll memorize what angles to type in. For example 90 degrees down would be equivalent to 270 or -90.
    Junior Member
    not specified
    Jul 2006
    Tacoma, Washington
    23
    CarlB
    Thanks for the reply.
    The program that I'm using right now is AutoCad 2007 without microvellum. At this current time there is no measuring system showing. (I know there is one. Is that the key to understanding this? Because I can't figure out how you would know it's 30 degrees without one.)
  5. #5
    Forum Deity
    not specified
    Jul 2004
    Anchorage, Alaska
    2,074
    You're right, the figure is not entirely clear but it appears safe to asume the line from 4.5,2.2 to the right is horizontal - or 0 degrees. Since from geometry we know that a 180 degree angle would have been a straight line, the deflection angle (from 0 degrees) is 180 - 150 = 30 degrees. When you get to the 1.6 long segment, again assuming the 2.1 long segment is vertical (90 degrees), the 150 angle will translate to a line at 120 degrees.
  6. #6
    Junior Member
    not specified
    Jul 2006
    Tacoma, Washington
    23
    whoo-boy am I going to need a lot of practice. Slowly starting to get it..
    Thanks
  7. #7
    Banned Alan Cullen's Avatar
    Map 3D 2009
    Jun 2006
    Cairns, Queensland, Australia
    4,181
    Anna,
    You can reset your units....we are Civil Engineers and we allways use conventional mapping grids.... i.e. North 0 deg, East 90 deg, South 180 deg and West 270 deg.
    Use the UNITS command and fill the "Drawing Units" dialogue box in as follows...
    Length
    Type.......... Decimal
    Precission... 0.000 (or whatever to suit)
    Angle
    Type.......... Deg/Min/Sec
    Precission... 0d00'00" (or whatever to suit)
    Clockwise..... tick
    Insertion Scale...... Unitless
    Direction
    North...... tick
    If you set all this up in your drawing template (acad.dwt ??), then all your drawings will have your unit preferences automatically.
  8. #8
    Junior Member
    not specified
    Jul 2006
    Tacoma, Washington
    23
    I got this one down now, with a little help, thanks to all who commented.
