Results 1 to 2 of 2
    Senior Member sandiegophil's Avatar
    sandiegophil's Computer Details
    Windows 10 64bit
    HP z640
    E5-2609 v4 1.7GHz
    64gb
    nvidia m3000
    ssd
    2-Z27s
    Civil
    sandiegophil's Discipline Details
    CAD Manager - County of San Diego DPW
    Civil
    Civil 3D 2018
    Feb 2009
    San Diego, CA
    271
    Default Alignment and profile problem
    Hello all,
    I have received a redesign from a sub that is a bit problematic. I will explain it as best I can. The plan has a main road alignment. I have received a redesigned pipe design. I have the pipe alignment, no problem there. It runs along the road alignment, not parallel, and crosses from one side of the road alignment to the other in several places. The issue is with the pipe profile. The sub created, reused, my road alignment profile and drew their pipe profile on it. They labeled station and elevations on their profile. The stationing is based on the road alignment and elevations are for their pipe profile. Since their profile is drawn on the road profile it is 'stretched' in some areas and greatly foreshortened in others.
    Does someone know of a slick way for me to project the pipe profile elevations to the pipe alignment so I can generate a feature line?
    Civil only wants to place the points on the road alignment.
    I'd just do it manually but it's about 3,500' and a lot of points.
    Thanks in advance for any help or ideas.
    Phil
    Additional info
    There are only a very few pipe profile elevations that match the pipe alignment geometry points.
    Senior Member JerryG's Avatar
    JerryG's Computer Details
    Never Good Enough
    My head
    Notebook
    Its big
    Civil
    JerryG's Discipline Details
    Stream Restoration
    Civil
    Civil 3D 2015
    Jan 2008
    Washington State
    418
    Wow phil it almost sounds like it would be easier to just recreate the pipe profile using its own Profile and stationing and then
    superimpose the new pipe profile onto the road profile. (if I understand what your saying correctly?)
    Never trust a computer you can't throw out a window!
  1. Referencing a profile to another alignment
    By SwChilly in forum Civil 3D & LDD
    Last Post: 11th Sep 2012, 03:41 pm
  2. change alignment start without destroying my profile
    By Mark_CV3D in forum Civil 3D & LDD
    Last Post: 25th Apr 2012, 08:46 am
  3. Profile View Rotation/Alignment
    By traumathecat in forum Civil 3D & LDD
    Last Post: 5th Aug 2011, 05:18 pm
  4. Problem Creating Profile from Alignment
    By rahulchandy in forum Civil 3D & LDD
    Last Post: 9th Mar 2010, 02:37 pm
  5. Profile elevation on Alignment
    By Hardney in forum Civil 3D & LDD
    Last Post: 12th Feb 2009, 05:12 pm
Tags for this Thread
