Find Missing text number in a layer
subodh_gis
How can we find a missing number from a number sequence in a text layer using Autolisp.
For ex-
1
2
3
4
6
7
in the above sequence 5 number is missing. so we should find 5 and zoom in to its nearest number as 4.
Actually we need it for parcel numbering where no number should be miss.
  • Replies 25
  • subodh_gis
    13
  • pBe
    10
  • MSasu
    2
  • BlackBox
    1
Posted Images
Subodh_gis, are you willing to write that code, so looking for some hints or request someone to write it for you?
:lol: I was about to write a demo code. lets wait for the OP to confirm his intent then.
Requesting someone to write it for me.
What about it boss? [MSasu], do you concur? :)
@Subodh_gis,
Anyhoo. you did not answer my question though
and bump the rest? i.e. 7 becomes 6 and 6 becomes 5?
It’s you time and benevolence, so please proceed at your wish my friend!
Sorry if my question sounded like a restriction. Is just that I really like to offer support to people that were willing to write the routines by themselves, so wanted to know if I may be involved.
@Subodh_gis,
No I just neet to find and zoom in.
No worries my friend :) I with you on that MSasu.
Find what? the next number of the missing digit? What if there are two missing digits? after the zoom then do what?
thanks for your support
find missing numbers and make list if we click on any number of missing list then zoom in to previous number of missing number. if no missing then Simple msg that no missing found. nothing to do after zoom in we will manually edit it.
It appears that you already have a program to find the missing numbers. What i was offering to you before was to auto-magically bump the numbers to accommodate the missing digits.
Your request just became more complicated with the addition of a list box.:D
Thanks for your kind support
Find the missing numbers and make a list of them if we click on any of missing number then zoom in to previous number of that missing number. if no missing number found then simple msg that no missing found. after zoom nothing to do we will manually edit it.
any thing that we can in this situation list box is not necessary. any other suggestion to complete missing sequence.
Ok, now lets get down to business, are these TEXT entity? are they on a particular layer? will this be via selection [per block i suppose]?
Uhhhmm sample drawing?
yes they are text entity. they are in "TXT01_PARCEL" layer.
I see, still no sample drawing :)
Here's a simple code: forced to re-number everything regardless what is the missing digit
the OP "dont need this actually"
We can add a sub to find the lowest missing number and start from there [maybe later].
[b]***CODE MOVED TO POST # 24***[/b]
Edited by pBe
(defun c:filler	(/ _missing cont ss str i missed num)
 (if (setq cont nil
    ss	 (ssget "_:L" '((0 . "TEXT") (8 . "TXT01_PARCEL")))
(setq str
       (cdr
	 (assoc 1 (entget (setq e (ssname ss (Setq i (1- i))))))
(if (numberp (setq v (read str)))
  (setq cont (cons (list v e) cont))
     (setq cont (vl-sort cont
		  '(lambda (j k)
		     (< (car j) (car k))
     (if (> (car (last cont)) (length cont))
  (setq num 0)
  (foreach val cont
    (vla-put-textstring
      (vlax-ename->vla-object (cadr val))
      (itoa (setq num (1+ num)))
)(vl-load-com)
I don't need this actually.
Thats gratitude for you. :glare:
It's unfortunate, I was planning to re-write the code to meet other conditions and also to include a list box.
Post a sample drawing then.
Dear see the attached sample or can you come on Team Viewer so that i can show you.
sample.dwg
