j4cksincl4ir Posted November 13, 2013 Share Posted November 13, 2013 I have received a measured survey drawing from a survey that I wish to print out on A3. The drawing and the title block are both in Model Space. When I measure the structural opening of a door, I found that the dimensions are in meters. On the title block, the denoted scale is 1:100. I am simply trying to replicate this in paper space in order to print out this plan on A3 paper at 1:100. By the time I have worked through Page Set up Manager and chosen the scale of 1:100, the floor plan inside its border looks like a postage stamp. I have tried Format > Units and changing the drawing units from unitless to meters but this doesn't change anything. I have also tried scaling the model space drawing x1000 but this makes the drawing too big in paper space at 1:100. What is going on? Quote Link to comment Share on other sites More sharing options...
eldon Posted November 13, 2013 Share Posted November 13, 2013 AutoCAD defaults to plotting in millimetres. So for a drawing in metres, you have to introduce an extra 1000 factor. For your A3 to be plotted at 1:100, your scale factor is 1000/100, i.e. 10:1. Try that and see if it looks better. If that scale is not in the list of available scales, try a Custom scale of 10. Quote Link to comment Share on other sites More sharing options...
j4cksincl4ir Posted November 13, 2013 Author Share Posted November 13, 2013 Thank you. Yes, 10:1 does look better but it is too big for my A3. The original 1:1 model space dimensions of the title block border is 110.965 x 77.6 so it looks as if keeping the 1:100 scale won't be possible on A3. Quote Link to comment Share on other sites More sharing options...
eldon Posted November 13, 2013 Share Posted November 13, 2013 The original 1:1 model space dimensions of the title block border is 110.965 x 77.6 so it looks as if keeping the 1:100 scale won't be possible on A3. That size looks like an A0 at 1 to 100. To get it on an A3, the scale would have to be about 1:300. Perhaps you will have to revert to Scale to fit Quote Link to comment Share on other sites More sharing options...
