cad_cow Posted November 13, 2013 Share Posted November 13, 2013 Hi all....i have another perplexing issue this week. Suddenly my cad is playing up when i try and select single items. For instance....if i lay a block over another block (different looking blocks, not identical), then select the block underneath (making sure the other block is not selected), when i move said block, it moves both. The only way i can separate these two is by deletion. It deletes selected block fine, but wont move it separately, always moves both as if stuck together? Just now i tried to stretch a polyline...it selects the one, but when i stretch it moves the whole row. I have included pics of this to demonstrate. Am i going nuts? Quote Link to comment Share on other sites More sharing options...
rkent Posted November 14, 2013 Share Posted November 14, 2013 You have INFER constraints set to on. Near the Lower left of the screen. Then delete constraints with DELCONSTRAINTS command, from command line or ribbon. Quote Link to comment Share on other sites More sharing options...
SAFeSTeR Posted November 14, 2013 Share Posted November 14, 2013 You may also want to check your selection cycling using Ctrl-W (also located in the lower left of the screen). Quote Link to comment Share on other sites More sharing options...
