Page 1 of 2 1 2 LastLast
Results 1 to 10 of 17
    Full Member
    AutoCAD 2004
    Aug 2007
    39
    Default automate flattening all entities residing inside blocks
    I am looking for ways to automate flattening all entities residing inside blocks. I have searched all over the internet but haven't found one, maybe because my search term is not correct, or something. Here is what I am looking for:-
    Open a file (this can be manually or automate through batch file)
    Run a script / routine which does all things below all by itself:-
    -- edit a block by opening it in block editor
    -- runs flatten command or any other method to set all lines, arcs, etc to Z=0 coordinate
    -- save block and exit block editor
    -- open next block and repeat above steps
    -- stops only when all block in the drawing are redefined as above
    Is it possible?
    Note: using AutoCAD 2012. Lines are not imported from 3D content, just a result of careless drafting.
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,040
    I moved your thread to the AutoLISP, Visual LISP & DCL since you are not using AutoCAD LT.
    Lee Mac's Computer Details
    Win 7 Pro / Win 10 Pro / Linux Mint
    Multi-disciplinary
    Lee Mac's Discipline Details
    Multi-disciplinary
    AutoCAD 2018
    Aug 2008
    London, England
    19,501
    Here is a very simple program to flatten all objects in all blocks & layouts:
    Code:
    (defun c:allflat ( / d )
        (vlax-for b (vla-get-blocks (setq d (vla-get-activedocument (vlax-get-acad-object))))
            (if (= :vlax-false (vla-get-isxref b))
                (vlax-for o b
                    (if (vlax-write-enabled-p o)
                        (foreach e '(1e99 -1e99)
                            (vlax-invoke o 'move '(0.0 0.0 0.0) (list 0.0 0.0 e))
        (vla-regen d acallviewports)
    (vl-load-com) (princ)
    You can very easily run the above program on multiple drawings using a batch processing program, such as my Script Writer program.
    Lee Mac ProgrammingTwitterExchange App StoreDropbox (500MB free)
    Full Member
    AutoCAD 2004
    Aug 2007
    39
    Quote Originally Posted by Lee Mac View Post
    Thanks a lot Lee Mac. Works like a charm. On a simple file it finished so fast I first thought it did not do anything!
    I did a little test to test how your insertion points behave.
    Block 01:- Rectangle at z=0, block defined and base point selected at z=0. Rectangle moved to z=50 in block editor. Block inserted on line lying at z=0. Block rectangle still comes on z=0. Good.
    Block 02:- lines at various z coordinate. Block defined and base point selected at z=50 (intersection of two green lines).
    Instance 1:-Insert at Z=0
    Instance 2:- insert at Z=50 (on RHS)
    Run "Allflat" script and voila! everything is at z=0. What amazes me most is that second instance of block 02 is also now lying flat on z 0. My own conclusion is that base point definition does not have z value.
    Can't wait to try it out on all those big messy drawings come Monday.
    PS: I am somehow unable to upload image to CADTutor. Moderators please edit as required.
  5. #5
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD 2018
    Aug 2008
    London, England
    19,501
    Quote Originally Posted by Guite View Post
    You're most welcome!
    This is because the base point of a block reference is merely the position of the block definition geometry relative to the origin of the block definition (very rarely is the origin of the block definition not at 0,0,0).
    Hence, when running the program, since the objects within the block definition are also 'flattened', the base point is automatically repositioned accordingly.
    The images appeared fine for me
  6. #6
    IBM Lenovo
    ACPI x64
    8 GB RAM
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,040
    I do not see them at work which filters images from third party sites. Is the image hosted at a third party site? If you just post them to CADTutor, they should show up.
  7. #7
    Full Member
    AutoCAD 2004
    Aug 2007
    39
    The image is hosted on third party site. I could not upload to CADTutor for some reason. It just never finishes uploading
  8. #8
    IBM Lenovo
    ACPI x64
    8 GB RAM
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,040
    What is the size of the file? Images load just fine here for me.
  9. #9
    Full Member
    AutoCAD 2004
    Aug 2007
    39
    Dear Lee Mac,
    I am encountering weird behaviors after running Allflat. This is not to say that it does not work at all. Infact it runs pretty well in most files. It handled dynamic blocks pretty well.
    - Some blocks behave strangely (files attached). The blocks were carelessly defined to start with. Re-defining them will be too time consuming.
    - Hatches disappear in one drawing, may have moved to very far coordinate. X-ref moves away in same file. E-transmit file attached.
    - Entities get scattered. Please refer Cutouts before and after.
    I have also tried native flatten command on some of the files. While there is less or no scattering, block insertion Z do not move every time to 0.
    I am attaching these files incase you would like to troubleshoot and develop the script further. If you don't feel like, I am okay with it. I have restored my backups and will just as well live with it.
    Cheers,
    Guite
  10. #10
    Full Member
    AutoCAD 2004
    Aug 2007
    39
    Dear Lee Mac,
    Update: Allflat seems to have problem with handling blocks rotated other than 90 degrees to UCS axes. File attached for reference: run Allflat on this file and all angled parking blocks will scatter away.
    Cheers,
    Guite
  1. Replace LINETYPE with another one in dwg and all blocks inside.
    By ibach in forum AutoLISP, Visual LISP & DCL
    Last Post: 26th Dec 2012, 05:13 pm
  2. select last "n" entities drawn inside a lisp
    By flopo in forum AutoLISP, Visual LISP & DCL
    Last Post: 16th May 2011, 04:23 pm
  3. Find command for BLOCKS / ENTITIES
    By sadhu in forum AutoCAD Beginners' Area
    Last Post: 13th Oct 2010, 02:46 pm
  4. Fields inside blocks
    By Grigs in forum AutoLISP, Visual LISP & DCL
    Last Post: 29th May 2009, 06:13 pm
  5. Attributes inside Dynamic Blocks!! Help!!
    By Adrian in forum AutoCAD Drawing Management & Output
    Last Post: 8th Feb 2008, 03:30 pm
