dyanner Posted November 18, 2013 Share Posted November 18, 2013 Hi All, I'm trying to get a dynamic block to rotate the attached attributes from a left justification in the vertical position to a center justification in the horizontal position. I managed to do this with 2 Visibility States, but I was wondering if anyone has done this with only the one set of attributes. I'm using AutoCAD 2012. Thanks CB_test.dwg Quote Link to comment Share on other sites More sharing options...
Tuns Posted November 18, 2013 Share Posted November 18, 2013 Two visibility states is the best way to do it. You can also use EATTEDIT then click the "Text Options" tab and change the justification. Quote Link to comment Share on other sites More sharing options...
dyanner Posted November 18, 2013 Author Share Posted November 18, 2013 Thanks for the reply Quote Link to comment Share on other sites More sharing options...
