Page 2 of 5 FirstFirst 1 2 3 4 ... LastLast
Results 11 to 20 of 46
  1. #11
    Full Member
    AutoCAD 2012
    Feb 2013
    35
    I don't quite get what you're saying... I was doing a flat (2d if that's what you mean) drawing in isometric view, I only started with the 3d at your suggestion for the U-bolt. I learned a good deal about 3D drawing a few years ago, but tend to stay away from it on most things because I get frustrated with things snapping the the wrong sides of things and only realize it after rotating the view to another angle. I've actually been doing this for awhile, but for the most part (until recently) the drawings I've been asked to do are so spread out I find myself having to go back and relearn what commands I need to accomplish something and/or how to use those commands again.
    Pretty much all the work I've done with Autocad has been 2D work, and due to time limitations, many times it's just been simple line drawings of tank batteries, rather than actually drawing out the pipes, valves, fittings etc. I have no problem doing plan view, and elevation view drawings, where I know exactly what the angles need to be, but when It comes to isometric drawings I get stuck trying to figure out how to make things look right. Seems like I ran into similar problems in 3D, trying to figure out how to get fittings/pipe to snap to the spot I want on the tanks. That the frustration with things snapping to the wrong side of something, and I just cant tell. And wireframe sometimes just makes everything even more confusing.
    I took a class on autocad and got my associate certification, but they had no offerings for 3D modeling to further my knowledge in that aspect.
    I forgot to mention, I know this particular drawing doesn't have to be perfect, as I stated earlier I figured out a way to do it originally that got the point across, and just explained it in my email that the ubolt wouldn't be all thread, but I would prefer my drawings to look more professional, and situations like this give me a way to learn how to get the desired results.
  2. #12
    Forum Deity rkent's Avatar
    rkent's Computer Details
    WIN7 PRO 64bit
    Dell OptiPlex 7020
    i7 4790 3.6GHz
    16GB, 1600MHz, DDR3 non-ECC 2x8GB
    AMD Radeon 2GB
    Samsung 480Gb SSD
    Dell 24" FS (2x)
    Mechanical
    rkent's Discipline Details
    Mechanical
    Mechanical 2017
    Nov 2007
    4,590
    mrkmpn - I agree with the guidance to draw that in 3D. For your Isometric - if you simply want to make your u-bolt not look like it is made from all-thread, just erase the ellipses along the curve of the u-bolt and down along the straight part as far as necessary.
    Sometimes there's a man... I won't say a hero, 'cause, what's a hero? But sometimes, there's a man. And I'm talkin' about the Dude here. Sometimes, there's a man, well, he's the man for his time and place. He fits right in there. And that's the Dude, in Los Angeles. - The Stranger, The Big Lebowski
  3. #13
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,838
    mrkmpn: Any chance you are using the old 2D isometric mode that is accessed via SNAP > STYLE > ISOMETRIC and the crosshairs (for the isometric planes) are controlled via the F5 key?
  4. #14
    Senior Member
    Manufacture
    gazza_au's Discipline Details
    Engineering
    Manufacture
    Management/Stainless Fabrication/Design/Drafting
    AutoCAD 2015
    Apr 2010
    Australia
    132
    Here you go.
    U-BOLTS-.dwg
  5. #15
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,838
    gazza_au: It might be nice to mention the source of the drawing that you provided (looks like Andry Brenkman's AutoCAD 2004 drawing posted over at the CADforum). I think the OP wants to know "how" it would be done and not necessarily have it provided for him. BTW...there are no threads on any of the U-bolts in Brenkman's drawing which is one of the things discussed by the OP.
  6. #16
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,838
    One way to create a 3D U-Bolt. Everything in the image was created in a top down view using a 2Dwireframe visual style.
    On the far left is my 2D centerlines. The red lines represent the threaded portion of the U-bolt. The yellow objects you see are 3D solids. The smooth top portion of the U-bolt was created by sweeping a circle while the "threads" were created by revolving a closed profile. Since all we need is a pictorial view I see no reason to use a helix and a swept profile of the tooth. On the far right is the 3D model of the threads. Are you with me so far?
  7. #17
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,838
    Now what's changed?
    I've simply switched to the standard SW Isometric view of my objects and used a Conceptual visual style. Nothing has been rotated at this point.
  8. #18
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,838
    Can you see me now?
    To achieve this I changed the orientation of my UCS and rotated the 3D solids. I moved the single solid thread to one leg of my U-bolt and copied it to the second. I unioned everything together and switched to a Realistic visual style. It probably took no more than 5 minutes to create.
    Note that changing your UCS can be done manually (old school) or via the Dynamic UCS. Choose the option you feel the most comfortable with.
    Disclaimer: The above was meant for demonstration purposes only. Any semblance to accuracy was purely accidental!
  9. #19
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,838
    The threads were bugging me so I changed them from very coarse to fine.
  10. #20
    Full Member
    AutoCAD 2012
    Feb 2013
    35
    Yes, I think maybe that's where to confusion comes in. For most things that's the easiest way for me to get a 3D look without having to do it all in 3D.
  1. Hex nut / bolt head in isometric
    By Adam in forum AutoCAD Beginners' Area
    Last Post: 27th Aug 2013, 11:26 pm
  2. Need help in isometric drawing.
    By Valamu in forum AutoCAD Beginners' Area
    Last Post: 26th May 2010, 11:58 am
  3. drawing a bolt
    By Elektryk in forum AutoCAD 3D Modelling & Rendering
    Last Post: 20th Jan 2010, 04:36 am
  4. Isometric Drawing pt. 2
    By J-Rod#1 in forum AutoCAD Beginners' Area
    Last Post: 4th Dec 2008, 09:34 am
  5. Isometric drawing
    By whel_13 in forum Catch All
    Last Post: 10th May 2003, 05:29 am
