Results 1 to 10 of 10
Thread: Auto-numbering
    Forum Newbie
    not specified
    Aug 2005
    5
    Default Auto-numbering
    I would like to learn how to write a LISP routine? or whatever it would take so I can automatically number my blocks as I insert them. Or copy a text entity so that every time I paste it, it is the next numeral in the order. I would like to start with the number "001" and every time I paste it, it is "002" then "003" to infinity. If you could help me or direct me to how I can help myself, I would greatly appreciate it.
    Super Moderator rkmcswain's Avatar
    rkmcswain's Computer Details
    Windows 7 Pro x64
    Intel DZ77RE-75K
    i7-3770K 3.50GHz
    32GB
    Nvidia Quadro 2000
    125GB SSD
    500GB SATA
    ASUS 27" / ASUS 24"
    Civil
    Civil 3D 2013
    Sep 2005
    Houston
    3,633
    Here is a basic version of what you want. It does not add the leading zeros however. Study this and read up on lisp in the developers help (\help\acad_dev.chm) and you should be able to modify this to suit your needs.
    Code:
    (defun c:autonum (/ *ms* pt)
      (vl-load-com)
      (setq *ms* (vla-get-modelspace
                   (vla-get-activedocument (vlax-get-acad-object))
      (if (not (eq (type autonumi) 'INT))
        (setq autonumi 1)
      (while (setq pt (getpoint "\n Select point: "))
        (vla-addtext
          *ms*
          (rtos autonumi 2 0)
          (vlax-3d-point pt)
          (getvar "textsize")
        (setq autonumi (1+ autonumi))
    Forum Newbie
    not specified
    Aug 2005
    5
    Thanks alot, but I guess I am far less advanced than you think I am? I know my way around AutoCAD but I don't know anything about LISP. I don't know what to do with this. I know I load application but after that I don't know what to do to even see if it is what I want or how I should modify it. Also, where do I find the help link you gave?
    Banned Alan Cullen's Avatar
    Map 3D 2009
    Jun 2006
    Cairns, Queensland, Australia
    4,181
    I think I understand what you are trying to achieve, but I don't understand why !!!!!!
    You can do what you want through a lisp routine....insert a block (any block name) and place sequential text number beside that block. Unfortunately the lisp code will be somewhat complex and take some time to write, and I don't have such a lisp routine to give you (because I've never needed to do this).
    rkmcswain wrote you some basic code, it will place sequential text numbering at any point you pick. Before you use it you must select the layer you want to be current, select the colour you want to be current, and more importantly, select the text font and size you want to be current.
    Copy/paste the code to a text editor (notepad) and save it to a file name (e.g. "autonum.lsp") at a location where Autocad can find it (TOOLS -> OPTIONS -> Files -> Support File Search Path). Then to load it type at the command line (load"autonum"). Then to fire it up type AUTONUM at the command line.
    I realise this doesn't really give you a definitive answer, But I hope it helps a little bit....
  5. #5
    Forum Newbie
    not specified
    Aug 2005
    5
    Why? I need to do this because my job requires that I insert approxametly 2000 individually numbered blocks into my drawings. I want to be able to just copy and paste my block with a number next to it and every time I place the block, it be numbered accordingly. If you know of a better way to do this, please let me know. I don't want to edit this text 2000 times.
    Anyway, I saved the file and followed your instructions and it just says "unknown command". I'm sure this can't be as difficult as I seem to be making it?
  6. #6
    Senior Member kpblc's Avatar
    AutoCAD 2005
    May 2006
    Russia, St-Petersburg
    317
    What is the law of renumbering blocks? Renumber bock atts by order of creating? By x and y position? Or manually defining? What is the attribute tag?
    Until you not answer this questions, I think noone can helps you
    All I say is only my opinion.
  7. #7
    Forum Deity
    not specified
    Jul 2004
    Anchorage, Alaska
    2,074
    I'm guessing you had a problem at the point;
    (load "autonum") - did you use parentheses, did you get a response regarding a successful load? Another way to load the file is Tools>>Load Application>>browse to file>>Load.
    If this doesn't do what you want, do a web search, i've seen many a request/response for auto numbering blocks, blocks that increment with each copy, etc.
  8. #8
    Windows 7 Pro x64
    Intel DZ77RE-75K
    i7-3770K 3.50GHz
    32GB
    Nvidia Quadro 2000
    125GB SSD
    500GB SATA
    ASUS 27" / ASUS 24"
    Civil
    Civil 3D 2013
    Sep 2005
    Houston
    3,633
  9. #9
    Forum Newbie
    not specified
    Aug 2005
    5
    Wierd. I was trying to load it on my laptop which didn't work. I just loaded it on my pc and it works fine. Thanks for everyones help.
  10. #10
    Super Member CAB's Avatar
    AutoCAD 2000
    May 2004
    Tampa, Florida
    801
    There are many routines available to insert incremented text. Just search the net.
    Did you want to insert text or change an attribute as you inserted a block?
    The best way to get help with the latter is to post a drawing with your block in it.
    Otherwise the programmer must know the block name and the attribute tag to accomplish the task.
