Results 1 to 2 of 2
    Junior Member
    AutoCAD 2011
    Oct 2013
    14
    Default Select Blocks by Name & Attribute Property
    I know that you can select all instances of a block reference by using QSELECT and specifying Block Reference and then where "Name" equals your given block name.
    Is there a way to quickly select a block by name (exactly like the above), and then 'afterwards' reduce that selection down to just those blocks where attribute X is equal to a given string?
    TIA
    Super Member Murph_map's Avatar
    Murph_map's Computer Details
    Win 7, Win 8
    HP something or other and the laptop is an HP too
    2 gigs or 6 gigs in Laptop
    Utilities
    Murph_map's Discipline Details
    Boats and campers renting and repairs
    Utilities
    GIS and Map making.
    Map 3D 2016
    Feb 2011
    TN or KY depends if I'm at work or home.
    924
    Look at the FILTER command, not easy to set up for a beginner but once you create the filter(s) you can save them with the dwg.
    Murph
    Need a boat or camper for the weekend?
  1. A problem with ssget function ....How can i select all entitis have the same property
    By سبع الليل in forum AutoLISP, Visual LISP & DCL
    Last Post: 14th Nov 2013, 08:56 pm
  2. Select entities by color property.
    By teknomatika in forum AutoLISP, Visual LISP & DCL
    Last Post: 21st Sep 2011, 03:41 am
  3. select all polylines in the drawing based on its property using VBA
    By vivekgrs in forum AutoLISP, Visual LISP & DCL
    Last Post: 19th Jan 2009, 05:03 pm
  4. Multiple Attribute/Dynamic Property Filter?
    By verso in forum AutoCAD General
    Last Post: 7th Nov 2008, 04:53 pm
  5. Select ALL by property other than layer?
    By umop-3p!sdn in forum AutoCAD General
    Last Post: 16th Jun 2006, 05:36 am
