BeccaCad Posted November 21, 2013 Share Posted November 21, 2013 okay this is the information i have: Instruction is to draw a 2D net of the object described this is the drawing i have of the top and the front view of the object. i really need some help 13-4.tut.dwg Quote Link to comment Share on other sites More sharing options...
nestly Posted November 21, 2013 Share Posted November 21, 2013 I don't know what a "2D net" is? Quote Link to comment Share on other sites More sharing options...
BeccaCad Posted November 21, 2013 Author Share Posted November 21, 2013 13-7.dwg such as this octagonal prism Quote Link to comment Share on other sites More sharing options...
ReMark Posted November 21, 2013 Share Posted November 21, 2013 Are you trying to create a "development" (sometimes also referred to as a "pattern")? Quote Link to comment Share on other sites More sharing options...
BeccaCad Posted November 22, 2013 Author Share Posted November 22, 2013 I'm trying to make one similar to the one of the octagonal prism. I'm in Drafting I so it isn't too complicated. lol. Quote Link to comment Share on other sites More sharing options...
ReMark Posted November 22, 2013 Share Posted November 22, 2013 (edited) You're trying to do this in 3D? Are you trying to do something like this? Edited November 22, 2013 by ReMark Quote Link to comment Share on other sites More sharing options...
ReMark Posted November 22, 2013 Share Posted November 22, 2013 [ATTACH]45317[/ATTACH] such as this octagonal prism As part as I know the drawing you reference is called a development. For a video about creating a development of a prism and deriving its true shape see this.... Development of a cylinder can be found here... http://draftingmanuals.tpub.com/14040/css/14040_135.htm So there you have it. Your posts mentioned the word prism and cylinder and I've given you links to both. If you know drafting then you should be able to handle drawing either (or both). Quote Link to comment Share on other sites More sharing options...
ReMark Posted November 22, 2013 Share Posted November 22, 2013 And just in case you really were inquiring about slicing a 3D cylinder one option would be to use a surface which in the image above is just a line that was extruded. The SLICE command is invoked and the SURFACE option is used. Have we covered everything now? Quote Link to comment Share on other sites More sharing options...
ReMark Posted November 24, 2013 Share Posted November 24, 2013 BeccaCad, where did you go? Did you achieve your objective? Quote Link to comment Share on other sites More sharing options...
